Modify VBA to create a RULE to block multiple messages
Bruce Johnson
Outlook 2013 32 bit
Greetings all,
I have found this "CreateRuleForBlockingMultipleSenders" code that creates a rule for selected email.
However, each time I run it, ire cteates a NEW RULE with the same name, and a new set of sender to block...
What I would LIKE to to is to have the code MODIFY the CURRENT rule and then ADD the selected senders to that rule.
Here is the code (source was How to Quickly Create an Outlook Rule to Block the Senders of Multiple Emails )
Sub CreateRuleForBlockingMultipleSenders()
    Dim objRules As Outlook.Rules
    Dim objRule As Outlook.Rule
    Dim objMoveRuleAction As Outlook.MoveOrCopyRuleAction
    Dim objFromCondition As Outlook.ToOrFromRuleCondition
    Dim objSelection As Outlook.Selection
    Dim objMail As Outlook.mailItem
    Dim objJunkFolder As Outlook.Folder
    Set objRules = Application.Session.DefaultStore.GetRules()
    'Create a rule
    Set objRule = objRules.Create("Block Senders", olRuleReceive)
    Set objFromCondition = objRule.Conditions.From
    'Get the selected emails
    Set objSelection = Outlook.Application.ActiveExplorer.Selection
    'Get Junk Email folder
    Set objJunkFolder = Outlook.Application.Session.GetDefaultFolder(olFolderJunk)
    For i = objSelection.Count To 1 Step -1
        If objSelection.Item(i).Class = olMail Then
           Set objMail = objSelection.Item(i)
           'Add the email senders to rule condition
           With objFromCondition
                .Enabled = True
                .Recipients.Add objMail.SenderEmailAddress
                .Recipients.ResolveAll
           'Move the emails from blocked senders to Junk Email folder
           Set objMoveRuleAction = objRule.Actions.MoveToFolder
           With objMoveRuleAction
                .Enabled = True
                .Folder = objJunkFolder
    objRules.Save
Thanks in advance!
Mc
S VBA to modify appointment item in additional Exchange account doesn't work Using Outlook 0
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
S Modify account template? BCM (Business Contact Manager) 0
R Can't modify Outlook view font with IE anymore (even though IE still affects print font) Using Outlook 5
smokiibear How to modify Today Page to Include tasks from other task folders Using Outlook 1
S Modify recurring outlook invites based on form entry Using Outlook 0
C How To Open Outlook Attachment in Excel, Modify some Data, then Re-Save It Using Outlook 3
A Possible to modify people preview window? Using Outlook 1
R How to modify Outlook Select Rooms form columns Using Outlook 1
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
N modify New mesage SEND button Outlook VBA and Custom Forms 1
R Custom Archive code -- modify my code! Outlook VBA and Custom Forms 3
C How do I grab a field property (like .value) so I can modify it via OL code? Outlook VBA and Custom Forms 4
A Script to either modify "from" address or prevent a reply being se Outlook VBA and Custom Forms 2
B Can't modify PR_CLIENT_SUBMIT_TIME? Outlook VBA and Custom Forms 1
