using VBA to edit subject line
holleymc
Outlook 365 32 bit
Outlook version:     Outlook 365
Email type or host:    Exchange
Hello all and many thanks for all past help! After searching, I believe I have found what I need to remove a phrase in emails, but when I run the code, I get the error
and this is what I see when debugging.
Here is my code:
Sub Remove_OTP()
Dim arr As Variant, i As Long
arr = Array("This is where the text is.xlsx at ")
For i = 0 To UBound(arr)
oitem.Subject = Replace(oitem.Subject, arr(i), "", , , vbTextCompare)
oitem.Subject = Trim(oitem.Subject)
oitem.Save
Any suggestions would be most appreciated. Many thanks in advance!
U Using VBA to creat hyperlinks in an email Outlook VBA and Custom Forms 3
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
Diane Poremsky Create a Series of Tasks using VBA Using Outlook 0
Diane Poremsky Paste clipboard contents using VBA Using Outlook 0
L Clear Offline (Task) Items using VBA Outlook VBA and Custom Forms 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Using VBA to disable alerts / warnings Using Outlook 2
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
M using Folders.Count in Excel Vba Outlook VBA and Custom Forms 8
M VBA Send Sales reports using .oft files, originate in Outlook or Excel? Using Outlook 5
A Outlook VBA - moving mail item to public folder using variable within path Using Outlook 6
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
D Update existing rule using VBA Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
J Add categories to Shared Mailbox using VBA Using Outlook 2
R Limiting meeting attendees using VBA or an add-in Using Outlook 9
J Create new outlook task into task subfolder using vba Using Outlook 6
S Send All emails in Outbox and Quit using VBA Outlook VBA and Custom Forms 3
R Outlook and Access integration using VBA Outlook VBA and Custom Forms 1
U using VBA to set message sensitivity Outlook VBA and Custom Forms 1
D Using VBA to send Word document as body of message works in 2007, but not in 2003 Outlook VBA and Custom Forms 9
