Using VBA to send Word document as body of message works in 2007, but not in 2003
  • Thread starter Doug Robbins - Word MVP
  • Start date
Based on Sue Mosher's code at
http://www.outlookcode.com/codedetail.aspx?id=1333, the following code,
which is located inside a With ActiveDocument - End With construction, works
fine in Word 2007:
Set objDoc = .MailEnvelope.Item
With objDoc
> To = strEmail
> Subject = strSubject
> Save
strID = .EntryID
Set objDoc = Nothing
Set objDoc =
oOutlookApp.Session.GetItemFromID(strID)
With objDoc
> Send
ObjDoc is declared as an Object and strID as a String and earlier in the
code there is the following:
Set oOutlookApp = GetObject(, "Outlook.Application")
If Err <> 0 Then
Set oOutlookApp = CreateObject("Outlook.Application")
bStarted = True
In Word 2003 however, it does not work and testing for strID using MsgBox
strID after it is set to .EntryID, I just get an empty message box so that
it appears that .EntryID is not being assigned.
Any clues on how to overcome this?
Regards,
Doug Robbins - Word MVP, originally posted via msnews.microsoft.com
As a followup, if I remove the On Error Resume Next, the following error
message is displayed:
430 Class does not support Automation or does not support expected interface
Regards,
"Doug Robbins - Word MVP" <dkr@REMOVECAPSmvps.org> wrote in message
news:B9A296D0-5B2C-46C1-93B1-A01C9A7C0583@microsoft.com...
> works fine in Word 2007:
> With objDoc
> .To = strEmail
> .Subject = strSubject
> .Save
> strID = .EntryID
> End With
> Set objDoc =
> With objDoc
> .Send
> End With
> If Err <> 0 Then
> bStarted = True
> End If
> > Regards,
Sue Mosher [MVP]
Which statement raises that error? You're running this code in Word VBA?
Sue Mosher
news:ef5ottSrKHA.5896@TK2MSFTNGP04.phx.gbl...
> interface
> > With objDoc
> > .To = strEmail
> > .Save
> > strID = .EntryID
> > End With
> > Set objDoc =
> > With objDoc
> > .Send
> > End With
> > If Err <> 0 Then
> > bStarted = True
> > End If
> > that it appears that .EntryID is not being assigned.
Hi Sue,
Yes, it is being run from Word. It is in the Word 2003 version of the
add-in that can be downloaded from:
http://www.gmayor.com/ManyToOne.htm
However, in the 2003 version that is available there, the "Merge to Email
Message" facility has been disabled.
The error is being caused by the
command. Note that line of code is inside a With ActiveDocument...End With
construction, and when writing the code, the intellisense provides
MailEnvelope.Item as a suggestion.
Regards,
"Sue Mosher [MVP]" <suemvp@gmail.com> wrote in message
news:u7E2jHTrKHA.728@TK2MSFTNGP04.phx.gbl...
> > Sue Mosher
> > interface
> >> With objDoc
> >> .To = strEmail
> >> .Save
> >> strID = .EntryID
> >> End With
> >> Set objDoc =
> >> With objDoc
> >> .Send
> >> End With
> >> If Err <> 0 Then
> >> bStarted = True
> >> End If
> >> MsgBox strID after it is set to .EntryID, I just get an empty message
> >> box so that it appears that .EntryID is not being assigned.
Sue Mosher [MVP]
What does ActiveDocument.MailEnvelope return?
Sue Mosher
news:OBxY0jTrKHA.3800@TK2MSFTNGP06.phx.gbl...
> Hi Sue,
> With construction, and when writing the code, the intellisense provides
> > Regards,
> >> interface
> >>> With objDoc
> >>> .To = strEmail
> >>> .Save
> >>> strID = .EntryID
> >>> End With
> >>> Set objDoc =
> >>> With objDoc
> >>> .Send
> >>> End With
> >>> the code there is the following:
> >>> If Err <> 0 Then
> >>> bStarted = True
> >>> End If
Hi Sue,
If I insert
MsgBox ActiveDocument.MailEnvelope
into the code, or just create a macro in the normal.dot template that
contains that code, in both cases, I get the Run-Time error '430' message
Class does not support Automation or does not support expected interface.
The same error message appears if I try and run the following code from the
VBA Help File:
ActiveDocument.MailEnvelope.Introduction = _
"Please review this document and let me know " & _
"what you think. I need your input by Friday." & _
" Thanks."
I have tried deleting Registry Keys, and re-registering Word, but that did
not make any difference
I have also tried running the code from
http://www.outlookcode.com/codedetail.aspx?id=1333 from Outlook, which did
not work and if I comment out the On Error Resume Next, I get the same error
message.
BTW, this was a fresh install of Office 2003 on a machine that previously
had 2010 Beta on it, but that was uninstalled before 2003 was installed and
the Registry Keys for Office 14.0 have been deleted.
Regards,
news:%23mu0mwarKHA.3792@TK2MSFTNGP05.phx.gbl...
> > Sue Mosher
> > Hi Sue,
>> > > Regards,
> >>> error message is displayed:
> >>> interface
> >>>> code, which is located inside a With ActiveDocument - End With
> >>>> construction, works fine in Word 2007:
> >>>> With objDoc
> >>>> .To = strEmail
> >>>> .Save
> >>>> strID = .EntryID
> >>>> End With
> >>>> Set objDoc =
> >>>> With objDoc
> >>>> .Send
> >>>> End With
> >>>> If Err <> 0 Then
> >>>> bStarted = True
> >>>> End If
Hi Sue,
While ActiveDocument.MailEnvelope also errors out in Word 2007, in that
version, ActiveDocument.MailEnvelope.Parent returns the name of the active
document, but it gives the 430 error message in Word 2003.
Also, I have now tried that on machines that have never had anything later
than Office 2003 installed on them with the same result.
Hope this helps,
Please reply only to the newsgroups unless you wish to obtain my services on
a paid professional basis.
> > Sue Mosher
> > Hi Sue,
>> > > Regards,
> >>> interface
> >>>> With objDoc
> >>>> .To = strEmail
> >>>> .Save
> >>>> strID = .EntryID
> >>>> End With
> >>>> Set objDoc =
> >>>> With objDoc
> >>>> .Send
> >>>> End With
> >>>> If Err <> 0 Then
> >>>> bStarted = True
> >>>> End If
Sue Mosher [MVP]
My guess is that the problem has to do with the 2010 installation. I have no
idea how to fix that. You might want to ask on the beta forum how to do a
complete uninstallation.
Sue Mosher
news:BB251675-C7E0-4172-A877-5AE61BFE3AA6@microsoft.com...
> Hi Sue,
> If I insert
> the VBA Help File:
> " Thanks."
> error message.
> and the Registry Keys for Office 14.0 have been deleted.
> > Regards,
> >> Hi Sue,
> >> Email Message" facility has been disabled.
>>> > >> Regards,
> >>> VBA?
> >>>> interface
> >>>>> With objDoc
> >>>>> .To = strEmail
> >>>>> .Save
> >>>>> strID = .EntryID
> >>>>> End With
> >>>>> Set objDoc =
> >>>>> With objDoc
> >>>>> .Send
> >>>>> End With
> >>>>> If Err <> 0 Then
> >>>>> bStarted = True
> >>>>> End If
Sue Mosher [MVP]
On the pure Office 2003 machines, did you install Outlook and Word from the
same SKU? If not, I think the Office Envelope functionality (among other
features) won't work.
Also, I don't know what you mean about this code being related to the
add-in. If add-ins are present, maybe disabling them would reveal something
useful.
Sue Mosher
news:C17CA250-3146-43B1-9F42-FE559A10C2DD@microsoft.com...
> Hi Sue,
> > Hope this helps,
> on
> >> Hi Sue,
>>> > >> Regards,
> >>> VBA?
> >>>> interface
> >>>>> With objDoc
> >>>>> .To = strEmail
> >>>>> .Save
> >>>>> strID = .EntryID
> >>>>> End With
> >>>>> Set objDoc =
> >>>>> With objDoc
> >>>>> .Send
> >>>>> End With
> >>>>> If Err <> 0 Then
> >>>>> bStarted = True
> >>>>> End If
Thanks, Sue.
I have now determined that it must be something to do with the particular
installation of Office.
Hope this helps.
Please reply to the newsgroup unless you wish to avail yourself of my
services on a paid consulting basis.
news:O$jZuRdrKHA.4460@TK2MSFTNGP05.phx.gbl...
> the same SKU? If not, I think the Office Envelope functionality (among
> other features) won't work.
> something useful.
> > Sue Mosher
> > Hi Sue,
> > active document, but it gives the 430 error message in Word 2003.
> > later than Office 2003 installed on them with the same result.
>> > > Hope this helps,
> > on
> >>> Hi Sue,
>>>> > >>> Regards,
> >>>> VBA?
> >>>>> interface
> >>>>>> With objDoc
> >>>>>> .To = strEmail
> >>>>>> .Save
> >>>>>> strID = .EntryID
> >>>>>> End With
> >>>>>> Set objDoc =
> >>>>>> With objDoc
> >>>>>> .Send
> >>>>>> End With
> >>>>>> If Err <> 0 Then
> >>>>>> bStarted = True
> >>>>>> End If
> >>>>>> message box so that it appears that .EntryID is not being assigned.
M VBA Send Sales reports using .oft files, originate in Outlook or Excel? Using Outlook 5
S Send All emails in Outbox and Quit using VBA Outlook VBA and Custom Forms 3
U Using VBA to creat hyperlinks in an email Outlook VBA and Custom Forms 3
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
Diane Poremsky Create a Series of Tasks using VBA Using Outlook 0
Diane Poremsky Paste clipboard contents using VBA Using Outlook 0
L Clear Offline (Task) Items using VBA Outlook VBA and Custom Forms 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Using VBA to disable alerts / warnings Using Outlook 2
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
M using Folders.Count in Excel Vba Outlook VBA and Custom Forms 8
A Outlook VBA - moving mail item to public folder using variable within path Using Outlook 6
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
D Update existing rule using VBA Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
J Add categories to Shared Mailbox using VBA Using Outlook 2
R Limiting meeting attendees using VBA or an add-in Using Outlook 9
J Create new outlook task into task subfolder using vba Using Outlook 6
R Outlook and Access integration using VBA Outlook VBA and Custom Forms 1
U using VBA to set message sensitivity Outlook VBA and Custom Forms 1
G Using VBA to load the CC line on an Outlook email Outlook VBA and Custom Forms 2
