NeatWorks export to contacts to BCM issues
MSIglobal
I scanned (many) business cards into Neatworks then imported to Outlook (reg
contacts.) Everything worked great. But when I exported those same contacts
into BCM, only the name & email address showed up, nothing else.
I have tried Neatwork support who says BCM was a plug in & they don't
support it. So is there a way to get all the contact info in contacts into
BCM?
Thanks in advance for your help
K
Karl Timmermans
Outlook and Outlook BCM are not the same. BCM uses an SQL based backend to
store its info. (as an aside it also uses a different import/export engine
then what is used in the standard Outlook product).
Instead of exporting directly from Neatworks to Outlook, export your data
first to Excel (which the Neatco website states is supported -
http://www.neatco.com/products/software/neatworks) and then import the Excel
file into BCM instead. You will be limited to whatever fields are included
by the Neatworks export process and whatever the BCM field map includes in
terms of Outlook.
Karl
_____________
ContactGenie - Importer 1.3 / DataPorter 2.0 / Exporter
"Power contact importers/exporters for MS Outlook '2000/2007"
"MSIglobal" <MSIglobal > wrote in message
news:35DA3067-751C-4B9F-945E-C1EE8EBFB412@microsoft.com...
> (reg
> contacts
> BCM?
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 4
K Export Folder to PST Outlook VBA and Custom Forms 2
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S How to export urls from email to excel and check the status of the url ? Using Outlook 5
C How to export Outlook data to csv? Using Outlook 0
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
avant-guvnor Export Calendar, Birthdays and Holidays Outlook VBA and Custom Forms 0
Diane Poremsky Export (Save) Outlook Contact photos Using Outlook 0
A How to export one email data to excel Using Outlook 1
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
E Exchanger service export detection Exchange Server Administration 1
R Correct a wrong csv export file from WLM 2012 Using Outlook 0
H How to export *all* fields from Outlook Using Outlook 2
K Export Organizational Forms Library Exchange Server Administration 1
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
A export free / busy from exchange Exchange Server Administration 0
C Export to excel missing items, but a larger total? BCM (Business Contact Manager) 6
M Outlook 2013/365 won't export 99% of my contacts to csv Using Outlook 2
T Outlook 2007 Export tasks to Excel Using Outlook 2
J Opening/Archiving/Import/Export PST files Using Outlook 4
H Select one of Contact-Mailadesses to Export > Excel or Winword Outlook VBA and Custom Forms 2
Sarge USMC Cannot import/export Outlook 13 Using Outlook 6
L Outlook 2007 Codes Export and Import Using Outlook 9
L Outlook 2007 Toolbar Export and Import Using Outlook 7
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
Jennifer Murphy Can I export individual emails? Using Outlook 1
R Export Address Book VBA Using Outlook 0
W How to export additional fields in contacts Using Outlook 1
R Recover/export rules from a backup .PST Using Outlook 2
J Formatting Contacts to Export for iPhone Using Outlook 0
B No export way Using Outlook 4
F Export Outlook contacts by One Category Using Outlook 1
Jennifer Murphy Difference between export and archive? Using Outlook 10
J How can I EXPORT my email address bok? Using Outlook 1
