BCM 2007 Can not create Offline Database
Mark Kolean
When setting up BCM it works correctly in online mode but when going to setup
the offline database it works for about 10 minutes then errors out with the
error "Outlook could not complete the following action or actions". I have
SQL 2005 Express SP3 installed and found 1 post relating to transaction files
sizes. I have tried this on 4 different laptops all with XP Pro 32bit
connecting to this database. On our personal network I am running BCM 2007
with a Vista Ultimate 64 bit and my offline works fine. Does anyone have any
experience with this problem???
Mark
L
Luther Blissett
On May 25, 7:09 am, Mark Kolean <MarkKol...
> Thanks
> Mark
Turn on BCM logging (In the BCM About dialog).
Reproduce the error, and check the log to see if it has additional
information about the error.
Mark Kolean
Sure here is the log of what is going on: One thing I didn't mention is that
when I am creating the offline file I am actually VPNing into our network
since this laptop is in a different state and maybe the database is timing
out during the sync. Is there a way to not have the connection time out so
it can work all night to sync would be the next question???
*************************************Message-1************************************
Initializing sync for sync point 'GoOffline' with producer
'Microsoft.BusinessSolutions.eCRM.DataSync.SqlRecordSetChangeListProducer',
consumer 'Microsoft.BusinessSolutions.eCRM.DataSync.SqlChangeListConsumer'
and conflict resolver '' on Thursday, May 28, 2009 4:07:09 PM.
*************************************Message-2************************************
Number of entities to synchronize = 61.
*************************************Message-3************************************
[Error]Error in synchronizing. Exception details follow
System.Data.SqlClient.SqlException: Timeout expired. The timeout period
elapsed prior to completion of the operation or the server is not responding.
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException
exception, Boolean breakConnection)
at
System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject
stateObj)
at
System.Data.SqlClient.TdsParserStateObject.ReadSniError(TdsParserStateObject
stateObj, UInt32 error)
at System.Data.SqlClient.TdsParserStateObject.ReadSni(DbAsyncResult
asyncResult, TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParserStateObject.ReadNetworkPacket()
at System.Data.SqlClient.TdsParserStateObject.ReadBuffer()
at System.Data.SqlClient.TdsParserStateObject.ReadByte()
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior,
SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet
bulkCopyHandler, TdsParserStateObject stateObj)
at
System.Data.SqlClient.TdsParser.TdsExecuteTransactionManagerRequest(Byte[]
buffer, TransactionManagerRequestType request, String transactionName,
TransactionManagerIsolationLevel isoLevel, Int32 timeout,
SqlInternalTransaction transaction, TdsParserStateObject stateObj, Boolean
isDelegateControlRequest)
at
System.Data.SqlClient.SqlInternalConnectionTds.ExecuteTransactionYukon(TransactionRequest
transactionRequest, String transactionName, IsolationLevel iso,
SqlInternalTransaction internalTransaction, Boolean isDelegateControlRequest)
at
System.Data.SqlClient.SqlInternalConnectionTds.ExecuteTransaction(TransactionRequest
transactionRequest, String name, IsolationLevel iso, SqlInternalTransaction
at System.Data.SqlClient.SqlInternalTransaction.Rollback()
at System.Data.SqlClient.SqlTransaction.Rollback()
at
Microsoft.BusinessSolutions.eCRM.DataSync.SqlChangeListConsumer.Microsoft.BusinessSolutions.eCRM.DataSync.IChangeListConsumer.ApplyChanges(ChangeList
changes, EventsManager eventsMgr)
at
Microsoft.BusinessSolutions.eCRM.DataSync.SyncManager.Synchronize(SyncPoint
sp, IContext producerContext, IContext consumerContext, SyncLog syncLog).
> > Thanks
> > Mark
M BCM 2007 Can't find SS2012Express Using Outlook 2
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
J No errors from BCM 2007 but can't see database BCM (Business Contact Manager) 0
S BCM 2007 to 2010 migration failure issue BCM (Business Contact Manager) 1
E BCM 2007 no reminder visible at client PC in workgroup BCM (Business Contact Manager) 5
U TABS MISSING OR DUPLICATED - BCM 2007 on Vista laptop BCM (Business Contact Manager) 5
J Unable to view History items in BCM 2007 shared database BCM (Business Contact Manager) 3
C BCM 2007 to 2010 Migration BCM (Business Contact Manager) 1
M Adding BCM to Outlook 2007 BCM (Business Contact Manager) 1
F Technical Specifications for 2007 BCM BCM (Business Contact Manager) 1
T BCM 2007: Accounts creation or opening fails BCM (Business Contact Manager) 1
J BCM V.2007 BCM (Business Contact Manager) 1
T BCM Crashing during search - 2007 edition BCM (Business Contact Manager) 3
H Fail to install BCM 2007 (English) on Windows 7 64 bit (Danish) BCM (Business Contact Manager) 3
A BCM 2007 restoring database BCM (Business Contact Manager) 1
V Already have Office 2007 Prof Plus, want to get BCM BCM (Business Contact Manager) 4
F Outlook 2007 BCM Exporting Files BCM (Business Contact Manager) 2
S Import Data from 2003 BCM to 2007 BCM (on Windows 7) BCM (Business Contact Manager) 1
D Connecting BCM 2007 to a shared BCM 2003 Database BCM (Business Contact Manager) 3
G bcm 2007 sub folders BCM (Business Contact Manager) 1
L How do you Recover from An Outlook 2007 & BCM Crash BCM (Business Contact Manager) 1
A Add BCM to outlook 2007 BCM (Business Contact Manager) 1
A BCM 2007 Shared Database on member Server 2008 in SBS 2008 Domain BCM (Business Contact Manager) 1
C Error when installing BCM for outlook 2007 from disk 2 BCM (Business Contact Manager) 3
B Outlook 2007 BCM will not recognize data files BCM (Business Contact Manager) 1
S BCM in Office Ultimate 2007 Won't Install on W7 Ultimate 32 BCM (Business Contact Manager) 1
D BCM 2010 and a shared BCM 2007 Database BCM (Business Contact Manager) 5
J BCM 2007 Shutting Down Outlook BCM (Business Contact Manager) 2
M cant find my BCM 2007 disc BCM (Business Contact Manager) 1
P Windows 7 / Outlook BCM 2007 Stability BCM (Business Contact Manager) 1
A What to do if BCM didn't install with 2007 Professional Trial? BCM (Business Contact Manager) 1
N Outlook 2007 w/BCM - Email issues BCM (Business Contact Manager) 5
N Email issues since installing BCM with Outlook 2007 BCM (Business Contact Manager) 1
M Outlook 2007 with BCM - Tasks being created automatically BCM (Business Contact Manager) 1
A Unresolved items, BCM 2007 with smartphone BCM (Business Contact Manager) 1
C All my projects and project tasks are gone - OL BCM 2007 BCM (Business Contact Manager) 2
J Moving BCM 2007 Database to a SQL 2005 Server BCM (Business Contact Manager) 2
D BCM 2007 errors BCM (Business Contact Manager) 5
D Outlook 2007 BCM - Win 7 BCM (Business Contact Manager) 1
W Recovering Data From BCM 2007 BCM (Business Contact Manager) 2
A ACT! 10.0 to BCM 2007 BCM (Business Contact Manager) 2
V Connecting BCM 2007 to SQL Server 2007 BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
B Marketing Campaign BCM 2007 – Word 2007 Merge Fails BCM (Business Contact Manager) 1
C How to configure BCM 2007 and Hosted Exchange BCM (Business Contact Manager) 4
D Networking BCM 2007 BCM (Business Contact Manager) 4
