BCM no longer loads SQLServer
John
Windows update installed IE8 and an Office 2007 upgrade last night. IE8
required a Microsoft Fix-It that "set all permissions to the default". After
that SQLServer stopped loading with a permissions error in the event log.
Does anyone know how to check the permissions for the SQLServer exe file?
John -- intelesoft.org
L
Luther Blissett
Doess the sqlserver Windows Service for MSSMLBIZ started automatically
with your system? Or does that fail?
John
Entered event error 3417 in Live Search and found that I needed to go to
Services, find SQL Server, right click on "Properties" then click the Log On
tab and set Log on as Local System Account. After I did that SQLServer
service started fine. But thanks for your help.
J BCM no longer loads sqlserver after SP2 upgrade BCM (Business Contact Manager) 2
C My BCM Database is no longer available to be shared with the Database Tool BCM (Business Contact Manager) 3
R BCM 2007 no longer showing up within Outlook 2007 BCM (Business Contact Manager) 3
