Better way of writing Macro? Identify multiple types of attachmen
  • Thread starter Thread starter hlock
H
hlock
I have 2 questions. The first one is 1) My macro does the job, but it really
seems to repeat itself. Is there a better way of writing it? My second
question is 2) we originally were just looking to identify .msg attachments.
Now however, we want to identify and separately process several other types
of attachments (.htm, .zip). I'm not very knowlegeable in vba. What is the
cleanest way to go from working with one extension to working with several?
I appreciate your help.
Public Sub StripAttachments()
Dim ns As Outlook.NameSpace
Dim Item As Object
Dim objAttachments As Outlook.attachments
Dim i As Long
Dim lngCount As Long
Dim strfile As String
Dim tempfile As String
Dim tempdir As String
Dim del As String ' ttimport delete parameter
Dim app As String ' ttimport application parameter
Dim result
Dim fso
Dim fil
Dim ext As String
Dim strsubject As String
Dim FileName As String
Dim path As String
Dim Response As VbMsgBoxResult
Set fso = CreateObject("Scripting.filesystemobject")
Set ns = GetNamespace("MAPI")
' Instantiate an Outlook Application object.
Set objApp = CreateObject("Outlook.Application")
Set objApp = Application
' Get the collection of selected objects.
Case "Explorer"
Set Item = objApp.ActiveExplorer.Selection.Item(1)
Case "Inspector"
Set Item = objApp.ActiveInspector.CurrentItem
Case Else
'Call SaveEmailNoAtt
app = "/a=clmdoc"
Set objAttachments = Item.attachments
lngCount = objAttachments.Count
If lngCount > 0 Then
For i = lngCount To 1 Step -1
strfile = objAttachments.Item(i).FileName
If Right(strfile, 3) = "msg" Then
If (FileExists("C:\Program Files\RLI\MSGImport.txt")) Then
MsgBox "This email contains attachments that are emails." &
vbCrLf & "Please process these attachments separately.", vbOKOnly +
vbExclamation
Response = MsgBox("This email requires special
handling and must be processed by ClaimHelp." & vbCrLf & "Do you wish to
forward to ClaimHelp now?", vbYesNo + vbExclamation)
If Response = vbYes Then
ForwardEmail
'MsgBox "This email requires special handling,
please forward it to ClaimHelp for processing.", vbOKOnly + vbExclamation
Next i
' Get the Temp folder.
tempdir = ("c:\temp\outlookimport\")
CheckFolder
strsubject = Item.Subject
FileName = StripIllegalChar(strsubject)
FileName = Replace(FileName, " ", "_")
If FileName = "" Then
FileName = "No Subject"
If fso.GetExtensionName(FileName) = "" Then
FileName = FileName & ".rtf"
ext = fso.GetExtensionName(FileName)
path = fso.BuildPath(tempdir, FileName)
Do While fso.FileExists(path)
tempfile = fso.GetTempName
tempfile = fso.GetBaseName(tempfile) & "." & ext
path = fso.BuildPath(tempdir, tempfile)
Loop
Item.SaveAs path, olRTF
Set fil = fso.GetFile(path)
path = fil.ShortPath
Set fil = Nothing
ExecCmd "ttimport.exe " & app & " " & path
Kill (path)
' Get the Attachments collection of the item.
' We need to use a count down loop for
' removing items from a collection. Otherwise,
' the loop counter gets confused and only every
' other item is removed.
' Get the file name.
If Right(strfile, 3) <> "msg" Then
strfile = Replace(strfile, " ", "_")
'Combine with the path to the Temp folder.
strfile = tempdir & strfile
' Save the attachment as a file.
objAttachments.Item(i).SaveAsFile strfile
ExecCmd "ttimport.exe " & app & " " & strfile
Kill (strfile)
Next i
'Item.Save
MsgBox "Email and attachments Saved Individually." & vbCrLf
& "Please verify your documents imported correctly." & vbCrLf & "Remember to
process the attached email separately!", vbOKOnly + vbExclamation
& "Please verify your documents imported correctly.", vbOKOnly
Next i
ExitSub:
Set objAttachments = Nothing
Set Item = Nothing
Set objApp = Nothing
'MsgBox "Email and attachments Saved Individually. Please verify your
1) Rather than force us to read through all your code, could you explain
what job the macro is supposed to accomplish?
2) Parse the attachment file name to extract the extension then use a series
of If ... Then ... ElseIf statements or, better, a Select Case block.
Sue Mosher
"hlock" <hlock> wrote in message
news:4556BBA2-1984-441D-B244-0D3789F4BC60@microsoft.com...
> really
> attachments.
> types
> the
> several?
> Dim objApp As Outlook.Application
> Dim Item As Object
> Dim i As Long
> Dim result
> Dim fso
> Dim fil
> Dim ext As String
> Dim path As String
> On Error Resume Next
> Select Case TypeName(objApp.ActiveWindow)
> Case "Explorer"
> Case "Inspector"
> Case Else
> End Select
> app = "/a=clmdoc"
> vbExclamation
> Else
> ForwardEmail
> Else
> End If
> Exit Sub
> End If
> End If
> Next i
> End If
> CheckFolder
> End If
> End If
> Loop
> Set fil = Nothing
> Kill (path)
> Kill (strfile)
> End If
> Next i
> End If
> 'Item.Save
> to
> Exit Sub
> Else
> Exit Sub
> End If
> Next i
> End If
> ExitSub:
> Set Item = Nothing
> End Sub
Re: Better way of writing Macro? Identify multiple types of attac
Sure - using our document repository executable, the macro saves the email by
itself as an rtf to our document repository, then it saves each attachment to
our document repository. The macro runs through the attachments 3x to look
at the attachments:
1. The macro looks at each attachment. If there is a .msg attachment and
the user has a particular file on their computer, they get a message, but the
macro continues. If the user does not have the file on their computer, the
macro ends.
2. The macro processes each attachment, except any attachment that is a
> .msg, and imports it to our document repository.
3. The macro looks at each attachment. If there is a .msg attachment, it
reminds the user to import the .msg attachment separately. If there isn't
any .msg attachments, it just reminds the user to check the imports.
I guess it's the running through of the attachments 3 different times that
seems redundant. However, it doesn't seem to slow down the macro and it
works. It just isn't very clean.
As for parsing the attachment file - is that using the right function and
taking the last 3 letters of the file? Thank you so much for your help.
> > Sue Mosher
> >really
> > attachments.
> > types
> > the
> > several?
> > Dim Item As Object
> > Dim i As Long
> > Dim result
> > Dim fso
> > Dim fil
> > Dim ext As String
> > Dim path As String
> > Case "Explorer"
> > Case "Inspector"
> > Case Else
> > End Select
> > app = "/a=clmdoc"
> > vbExclamation
> > Else
> > ForwardEmail
> > Else
> > End If
> > Exit Sub
> > End If
> > End If
> > Next i
> > End If
> > CheckFolder
> > End If
> > End If
> > Loop
> > Set fil = Nothing
> > Kill (path)
> > Kill (strfile)
> > End If
> > Next i
> > End If
> > 'Item.Save
> > to
> > Exit Sub
> > Else
> > Exit Sub
> > End If
> > Next i
> > End If
> > ExitSub:
> > Set Item = Nothing
> > End Sub
I agree that it's inefficient to handle each attachment 3 times. You should
consolidate your operations into one loop.
Most file extensions are 3 characters, so you can use Right() and succeed
most of the time. An even more certain approach would be to use the
InStrRev() function to locate the rightmost period in the file name and then
use Mid() to extract all characters to the right of the period.
Sue Mosher
news:4D722AAE-554B-4CE5-AA03-FA79D8BAA8D7@microsoft.com...
> by
> to
> look
> at the attachments:
> the
> the
> macro ends.
> > series
> > > > Sue Mosher
> > >really
> > > second
> > > attachments.
> > > types
> > > is
> > > the
> > > several?
> > > Dim Item As Object
> > > Dim i As Long
> > > Dim result
> > > Dim fso
> > > Dim fil
> > > Dim ext As String
> > > Dim path As String
> > > Case "Explorer"
> > > Case "Inspector"
> > > Case Else
> > > End Select
> > > app = "/a=clmdoc"
> > > Then
> > > emails." &
> > > vbExclamation
> > > Else
> > > to
> > > ForwardEmail
> > > vbExclamation
> > > Else
> > > End If
> > > Exit Sub
> > > End If
> > > End If
> > > Next i
> > > End If
> > > CheckFolder
> > > End If
> > > End If
> > > Loop
> > > Set fil = Nothing
> > > Kill (path)
> > > Kill (strfile)
> > > End If
> > > Next i
> > > End If
> > > 'Item.Save
> > > vbCrLf
> > > "Remember
> > > to
> > > Exit Sub
> > > Else
> > > vbCrLf
> > > Exit Sub
> > > End If
> > > Next i
> > > End If
> > > ExitSub:
> > > Set Item = Nothing
> >> > End Sub
Thank you. It's just that I don't know how I would consolidate the
operations into one loop. That's why I ended up with three separate loops.
Do you have any suggestions? I would appreciate any help you might provide.
> > Sue Mosher
> > by
> > to
> > look
> > at the attachments:
> > the
> > the
> > macro ends.
> >> series
> >> > >> Sue Mosher
> >> >really
> >> > second
> >> > attachments.
> >> > types
> >> > is
> >> > the
> >> > several?
> >> > Dim Item As Object
> >> > Dim i As Long
> >> > Dim result
> >> > Dim fso
> >> > Dim fil
> >> > Dim ext As String
> >> > Dim path As String
> >> > Case "Explorer"
> >> > Case "Inspector"
> >> > Case Else
> >> > End Select
> >> > app = "/a=clmdoc"
> >> > Then
> >> > emails." &
> >> > vbExclamation
> >> > Else
> >> > to
> >> > ForwardEmail
> >> > vbExclamation
> >> > Else
> >> > End If
> >> > Exit Sub
> >> > End If
> >> > End If
> >> > Next i
> >> > End If
> >> > CheckFolder
> >> > End If
> >> > End If
> >> > Loop
> >> > Set fil = Nothing
> >> > Kill (path)
> >> > Kill (strfile)
> >> > End If
> >> > Next i
> >> > End If
> >> > 'Item.Save
> >> > vbCrLf
> >> > "Remember
> >> > to
> >> > Exit Sub
> >> > Else
> >> > vbCrLf
> >> > Exit Sub
> >> > End If
> >> > Next i
> >> > End If
> >> > ExitSub:
> >> > Set Item = Nothing
> >> >> > End Sub
I would suggest that you analyze each loop for what it does and write it out
in "pseudocode" -- i.e. focusing on the operations and decision points, as
in a flow chart, without worrying about the actual code syntax. If you do
that, you should see where you can consolidate.
Sue Mosher
news:D5382E6A-629A-453E-B8D2-94A1E1F23548@microsoft.com...
> loops.
> provide.
> > should
> > then
> > > email
> > > by
> > > to
> > > look
> > > at the attachments:
> > > and
> > > but
> > > the
> > > the
> > > macro ends.
> > > a
> > > it
> > > isn't
> > > that
> > > it
> > > and
> > > help.
> > >> explain
> > >> series
> > >> > > >> Sue Mosher
> > >> >it
> > >> >really
> > >> > second
> > >> > attachments.
> > >> > other
> > >> > types
> > >> > What
> > >> > is
> > >> > the
> > >> > several?
> > >> > Dim Item As Object
> > >> > Dim i As Long
> > >> > Dim result
> > >> > Dim fso
> > >> > Dim fil
> > >> > Dim ext As String
> > >> > Dim path As String
> > >> > Case "Explorer"
> > >> > Case "Inspector"
> > >> > Case Else
> > >> > End Select
> > >> > app = "/a=clmdoc"
> > >> > Then
> > >> > emails." &
> > >> > vbExclamation
> > >> > Else
> > >> > special
> > >> > wish
> > >> > to
> > >> > ForwardEmail
> > >> > handling,
> > >> > vbExclamation
> > >> > Else
> > >> > End If
> > >> > Exit Sub
> > >> > End If
> > >> > End If
> > >> > Next i
> > >> > End If
> > >> > CheckFolder
> > >> > End If
> > >> > End If
> > >> > Loop
> > >> > Set fil = Nothing
> > >> > Kill (path)
> > >> > Kill (strfile)
> > >> > End If
> > >> > Next i
> > >> > End If
> > >> > 'Item.Save
> > >> > vbCrLf
> > >> > "Remember
> > >> > to
> > >> > Exit Sub
> > >> > Else
> > >> > vbCrLf
> > >> > Exit Sub
> > >> > End If
> > >> > Next i
> > >> > End If
> > >> > ExitSub:
> > >> > Set Item = Nothing
> > >> > your
> > >>> >> > End Sub
M Sorting "sent emails" is not logical. Is there a better way. Using Outlook 4
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
R writing "Instant Search" queries to find User-Defined fields Using Outlook 0
D Writing to BCM Database from VBA BCM (Business Contact Manager) 0
P writing to excel from outlook Outlook VBA and Custom Forms 3
L Help for writing an Outlook 2007 macro Outlook VBA and Custom Forms 7
