VBA for using Word Doc as Email Body
  • Thread starter Thread starter TGlzYWI
TGlzYWI
I am looking for VBA code to use in Access 2007 that would use a word
document as the body of an email.
I am very well able to automate emails from access. I have created several
applications that automate email from within the access program using .oft
templates, attachments, and other customizations.
However, this client wants to be able to use word documents as the email
template.
Any help would be greately appreciated.
This code is adapted from the sample at
http://www.outlookcode.com/codedetail.aspx?id=1333. It requires references
to both Outlook and Word libraries.
Sub SendDocAsMsg()
Dim wd As Word.Application
Dim doc As Word.Document
Dim itm As Outlook.MailItem
Dim ID As String
Dim blnWeOpenedWord As Boolean
Set wd = GetObject(, "Word.Application")
If wd Is Nothing Then
Set wd = CreateObject("Word.Application")
blnWeOpenedWord = True
Set doc = wd.Documents.Open _
(FileName:="C:\Current.doc", ReadOnly:=True)
Set itm = doc.MailEnvelope.Item
With itm
> To = "someone@somewhere.com"
> Subject = "My Subject"
> Send
doc.Close wdDoNotSaveChanges
If blnWeOpenedWord Then
wd.Quit
Set doc = Nothing
Set itm = Nothing
Set wd = Nothing
Sue Mosher
"Lisab" <Lisab> wrote in message
news:6935A534-300B-4713-8D2C-A07285E908D7@microsoft.com...
> several
> template.
OH, Thank You Very Much!
> Sub SendDocAsMsg()
> Dim ID As String
> On Error Resume Next
> End If
> With itm
> .To = "someone@somewhere.com"
> .Subject = "My Subject"
> .Send
> End With
> wd.Quit
> End If
> Set doc = Nothing
> Set itm = Nothing
> Set wd = Nothing
> End Sub
> > Sue Mosher
> > several
> > template.
D Using VBA to send Word document as body of message works in 2007, but not in 2003 Outlook VBA and Custom Forms 9
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
J Add Multiple Attachments Sources using VBA in Word Outlook VBA and Custom Forms 6
U Using VBA to creat hyperlinks in an email Outlook VBA and Custom Forms 3
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
Diane Poremsky Create a Series of Tasks using VBA Using Outlook 0
Diane Poremsky Paste clipboard contents using VBA Using Outlook 0
L Clear Offline (Task) Items using VBA Outlook VBA and Custom Forms 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Using VBA to disable alerts / warnings Using Outlook 2
P Saving All Messages to the Hard Drive Using VBA Outlook VBA and Custom Forms 5
M using Folders.Count in Excel Vba Outlook VBA and Custom Forms 8
M VBA Send Sales reports using .oft files, originate in Outlook or Excel? Using Outlook 5
A Outlook VBA - moving mail item to public folder using variable within path Using Outlook 6
P Automatic reply on incoming messages in outlook using VBA(only Specifi person) Using Outlook 14
D Update existing rule using VBA Using Outlook 2
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
J Add categories to Shared Mailbox using VBA Using Outlook 2
R Limiting meeting attendees using VBA or an add-in Using Outlook 9
J Create new outlook task into task subfolder using vba Using Outlook 6
