Reply to all Help needed badly
  • Thread starter Thread starter gbirdsong@gmail.com
G
gbirdsong@gmail.com
I know nothing about VBA in outlook but I need to create a macro. I
need to be able to highlight an email in my inbox and start the macro
which will reply to all for the highlighted email with a simple
message like "got it". How do I do this? Is there another way
besides a macro?
thanks
Sub DoReply()
Dim itm as Object
Dim reply as Outlook.MailItem
Set itm = Application.ActiveExplorer.Selection(1)
If itm.Class = olMail Then
Set reply = itm.ReplyAll
reply.Body = "Got it" & vbCrLf & vbCrLf & reply.Body
reply.Send
Set itm = Nothing
Set reply = Nothing
If you need basics on writing Outlook macros, see
http://outlookcode.com/article.aspx?id=49.
Sue Mosher
<gbirdsong@gmail.com> wrote in message
news:c21d07b9-182b-4807-b051-cf765bc13cbc@f18g2000vbf.googlegroups.com...
> besides a macro?
> thanks
On Apr 8, 2:29 pm, "Sue Mosher [MVP]" <sue...@turtleflock.com> wrote:
> Sub DoReply()
>     Dim itm as Object
>     On Error Resume Next
>         reply.Send
>     End If
>     Set itm = Nothing
>     Set reply = Nothing
> End Sub
> If you need basics on writing Outlook macros, seehttp://outlookcode.com/article.aspx?id=49.
> > Sue Mosher
that works great. thanks.
I will check out that site also.
> <gbirds...@gmail.com> wrote in message
> > besides a macro?
> > thanks
Is it possible to maintain the formatting of the original email in the
reply? The reply I am producing loses the spacing, text size, and
border lines from the original.
thanks
> > Sub DoReply()
> >     Dim itm as Object
> >         reply.Send
> >     End If
> >     Set itm = Nothing
> >     Set reply = Nothing
> > End Sub
> > > > Sue Mosher
> >news:c21d07b9-182b-4807-b051-cf765bc13cbc@f18g2000vbf.googlegroups.com....
> > > besides a macro?
> > > thanks
The Body property contains only the plain text representation of the item
body. If you want formatting, you need to work with HTMLBody and proper HTML
tags (instead of constants like vbCrLf).
Sue Mosher
news:76786a1d-92e6-43da-ba7f-8619945557bf@h28g2000yqd.googlegroups.com...
thanks
> > Sub DoReply()
> > Dim itm as Object
> > reply.Send
> > End If
> > Set itm = Nothing
> > Set reply = Nothing
> > End Sub
> > > besides a macro?
> > > thanks
P Automatically 'Reply to all', and Change the Subject of Email - Diane P help! Using Outlook 0
L Send reply when email is sent HELP! Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 2
G Reply a selected message and remove blank space before signature Outlook 365 version 2406 64BIT Outlook VBA and Custom Forms 0
T In-line reply style in Outlook II Outlook VBA and Custom Forms 1
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
P Automatic Greeting "Hello Name," when Reply All is clicked Outlook VBA and Custom Forms 1
W Reply to email Using Outlook 4
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
ThinkToday Calculate reply time of outlook mail Using Outlook 1
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
E reply Using Outlook 0
evdbogaard Reply with only last message cited Using Outlook 1
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J VBA Run When Reply Outlook VBA and Custom Forms 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
T In-line reply style in Outlook Outlook VBA and Custom Forms 20
Vijay Reply all by attachment name Using Outlook 10
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
