fix for Helvetica crasing Outlook 2010?
pamrr
Hi all,
I am a new Office Professional/Outlook 2010 user, and just went through the pain of finding out that Helvetica (True Type 1) crashes Outlook. I am a desktop publisher and rely heavily on this font. I know that there is a beta fix by MS, and I've found the page that lists the various fix files, but am not clear on which to download and install. All I want is to be pointed to the correct fix exe.
I am a big Adobe user, very much into fonts.
I am running Windows 7 on a 64-bit machine, and a 32-bit version of Office.
Pam
You need the hotfix in http://support.microsoft.com/kb/2459114 (their system is down right now tho). You need the 32-bit version of the hotfix because you are using the 32 bit version of Office.
Thanks, I've already been to that page. So that would be this file? :
Word2010-kb2459114-fullfile-x86-glb.exe
I just am not very good at decoding what they are saying on that page. That's why I came here.
And, is there a direct link to the page with the file? The only other way I can find the actual exe is to google it, but it'd be lovely if I could download it from microsoft themselves.
Thanks for your help.
Pam
That is the correct file for your version. I recommend using the Request hotfix link at the top of the page- it points to http://support.microsoft.com/hotfix/KBHotfix.aspx?kbnum=2459114&kbln=en-us. Microsoft will send you an email with a link to the download.
I do notice one thing that is not correct - its offering the 64bit update - i have windows 64 bit but outlook 32 bit on this computer and should be offered the 32bit. Clicking "Show hotfixes for all platforms and languages (2)" displays both files.
So thenthe file I want is word2010kb2459114fullfilex86glb, correct? It's the "86" that throws me off.
Thanks for your patience and understanding.
Pam
P Was Helvetica crashing Outlook, now fix has messed up explorer Using Outlook 4
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
H How to Fix 1510-370-1986 Garmin GPS Not Working Outlook VBA and Custom Forms 0
C How to fix outlook continuing to prompt fo an Exchange password Using Outlook 0
N May 2017 Fix Didn't Fix? Using Outlook.com accounts in Outlook 6
Micheal Ivan How to fix it ? BCM (Business Contact Manager) 1
J How to Fix “Encounter a large number of conflict items in Exchange OST file” Using Outlook 2
L Outlook 2007 Fix Phone Number Using Outlook 19
Diane Poremsky Fix the Outlook Folder Type after Exporting an IMAP Account Using Outlook 0
P Outlook 2007 Calendar Ribbon has changed and I can't fix it Using Outlook 10
M Outlook hidden even when open (maximising doesn't fix it) Using Outlook 2
P Can't fix my primary email account! Using Outlook 1
B Problem with fix for "Too Many Contact Folders" Using Outlook 3
M Deleted Meeting but didnt send notice to attendees, how to fix?? Using Outlook 1
G fix client/server conversation error message Exchange Server Administration 1
D Email Reminders show up only when in Outlook with Windows 7 - way to fix? Using Outlook 1
J Wasn't broke, went to fix it, now it's broke! Using Outlook.com accounts in Outlook 0
M Please can someone fix my Outlook Connector sync issue! Using Outlook.com accounts in Outlook 12
D outlook.exe application error - breakpoint has been reached. fix? BCM (Business Contact Manager) 1
R RE: Any Fix For Font & Spacing Issues in Outlook 2007? Using Outlook 2
P MICROSOFT OFFICE 2007 FREEZING UP HOW DO I FIX ? BCM (Business Contact Manager) 2
D Keeps Crasing - going mad Using Outlook 0
