Macro help
seanchad
HI All
I am trying to set up a macro so that when i press send i get prompted to select which email account i would like to send from. I am supposed to send emails from my works generic account rather than my personal one but i have the memory of a goldfish and hardly ever do this! I have read that you can change your default email address but i dont want to do this either as i will end up getting any personal non work related emails back to the teams generic account (again because of my dodgy memory!)
any help is much appreciated
Sean
We have a macro that always uses a specific account - you can add it to a button on the ribbon or tweak it to ask. Outlook 2010, Multiple Accounts and the Default Account | Slipstick Systems
Thanks for that. i have tried to use this macro but when i click the button it does nothing. Where it says to check the account name in account setting wjhen i do this all that is displayed is Microsoft Exchange Server.
Whewn viewing my inboxs i have both my account and the teams generic account underneath. If i am composing a message i can select the generic account using the from field but i always forget!
I currently have a macro in place so when i click send a pop up appears asking if i would like to encrypt my mail. I could do with something similar to this but where it asks what account i would like to send my email from.
Am i asking for a bit much here?!
Sean
the popup is doable, I'll take a look at it this evening (I have a deadline I need to meet right now, although macros are more fun than what I need to do for the deadline. :)) You'll probably need to use the sendonbehalf properly for a shared account - SendUsingAccount uses accounts configured in Outlook.
tell me about it i havent touched my work all day too busy trying to make life easier with a few macros!
Thank you for your help btw
it is much appreciated
thanks
sean
A newb outlook macro help Outlook VBA and Custom Forms 1
E Help with macro to answer and delete calendar requests? Outlook VBA and Custom Forms 5
A Help creating macro for conditional formatting settings Using Outlook 8
S Help macro Outlook VBA and Custom Forms 1
C Help with a Macro to move emails to a different PST data file Using Outlook 4
F Help with Outlook 2007 Macro Please! Using Outlook 4
S Outlook macro help Using Outlook 10
P Please Help me Create a Macro ! Using Outlook 2
D Help with simple macro - looping though all emails in my inbox Using Outlook 3
M Help - VB Macro no longer work Outlook VBA and Custom Forms 5
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
L Help for writing an Outlook 2007 macro Outlook VBA and Custom Forms 7
V Outlook macro help please Outlook VBA and Custom Forms 23
