Help macro
Sandro
Exchange Server 2010
I need to make a macro that when you receive an e-mail with subject "test" for example, it saves the body of the email in a html file.
Or a macro that opens an e-mail received in a new window.
Sorry for the mistakes, I'm using google translator ...
Oh, I'm pretty sure I have something at slipstick that comes close to this.
See http://www.slipstick.com/outlook/email/how-to-save-email-in-windows-file-system/ for links to macros to save different file types. http://www.slipstick.com/outlook/archive-outlook/save-incoming-messages-hard-drive/ saves the messages as msg files, but you can merge the codes and save as any file type.
How to use a run a script rule - http://www.slipstick.com/outlook/rules/outlooks-rules-and-alerts-run-a-script/ -
I don't think i have any samples opening a message, but you'd use item.display to open a message using a run a script rule.
A newb outlook macro help Outlook VBA and Custom Forms 1
E Help with macro to answer and delete calendar requests? Outlook VBA and Custom Forms 5
A Help creating macro for conditional formatting settings Using Outlook 8
C Help with a Macro to move emails to a different PST data file Using Outlook 4
F Help with Outlook 2007 Macro Please! Using Outlook 4
S Outlook macro help Using Outlook 10
P Please Help me Create a Macro ! Using Outlook 2
D Help with simple macro - looping though all emails in my inbox Using Outlook 3
S Macro help Using Outlook 4
M Help - VB Macro no longer work Outlook VBA and Custom Forms 5
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
L Help for writing an Outlook 2007 macro Outlook VBA and Custom Forms 7
V Outlook macro help please Outlook VBA and Custom Forms 23
