Export custom views from offline OST
JackPollack
I'm using a hosted Exchange account. My host had a really bad failure last week and basically had to rebuild from the ground up. This created a new mailbox for me which I had to import all of my data into (when I opened Outlook I got the option to use the offline version, or open the new mailbox).
I have since created a new mail profile with new OST file so Outlook opens without a problem and my data is there, but I had many custom folder views which I can still see in the offline copy, but cant figure out a way to export them. I tried saving the OST as a PST and also creating a new blank PST and adding folders and then copying the view (How to copy Microsoft Outlook custom views to backup or share - Outlook Tips). When I open the PST in the new mail profile the views didnt copy (maybe because OL is in the offline mode).
Is there any way I can recover these views at this point without having to create them manually?
(perhaps using mfcmapi which I just discovered, but dont fully understand)
MFCMAPI can't do it. It's going to be a PITA if you have many - you need to copy the view into the pst file as a 'this folder only' view then open the folder in the new profile and copy it as 'all folders'. i'm in the middle of something right now, but as soon as I'm finished, I will create a video that shows what to do - i suspect you are missing a step.
Are the views in the old ost for specific folders (this folder only view) or for all folders?
JackPollack
Some views are for specific folders, most are for all folders.
I'll check back for the video. Much appreciated.
I uploaded a video to youtube that shows how to do it.
[video=youtube_share;FC6e0pRZNxY]http://youtu.be/FC6e0pRZNxY[/video]
Because the views are "save" to the views folder, i could copy the entire folder to the new mailbox - but they would still only be for "this folder". If you have 'this folder' views in your old mailbox, you could more or copy the folder to the new mail box (by way of a pst) and move the views and the folder contents.
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
9 export custom form Outlook VBA and Custom Forms 2
T How to export custom form from exchange 2003 to exchange 2007 Outlook VBA and Custom Forms 2
C change the custom fields when export emails to excel Outlook VBA and Custom Forms 1
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 4
K Export Folder to PST Outlook VBA and Custom Forms 2
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S How to export urls from email to excel and check the status of the url ? Using Outlook 5
C How to export Outlook data to csv? Using Outlook 0
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
avant-guvnor Export Calendar, Birthdays and Holidays Outlook VBA and Custom Forms 0
Diane Poremsky Export (Save) Outlook Contact photos Using Outlook 0
A How to export one email data to excel Using Outlook 1
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
E Exchanger service export detection Exchange Server Administration 1
R Correct a wrong csv export file from WLM 2012 Using Outlook 0
H How to export *all* fields from Outlook Using Outlook 2
K Export Organizational Forms Library Exchange Server Administration 1
A export free / busy from exchange Exchange Server Administration 0
C Export to excel missing items, but a larger total? BCM (Business Contact Manager) 6
M Outlook 2013/365 won't export 99% of my contacts to csv Using Outlook 2
T Outlook 2007 Export tasks to Excel Using Outlook 2
J Opening/Archiving/Import/Export PST files Using Outlook 4
H Select one of Contact-Mailadesses to Export > Excel or Winword Outlook VBA and Custom Forms 2
Sarge USMC Cannot import/export Outlook 13 Using Outlook 6
L Outlook 2007 Codes Export and Import Using Outlook 9
L Outlook 2007 Toolbar Export and Import Using Outlook 7
S Requried a VBA Code to export Calander details to excel... Outlook VBA and Custom Forms 4
Jennifer Murphy Can I export individual emails? Using Outlook 1
R Export Address Book VBA Using Outlook 0
W How to export additional fields in contacts Using Outlook 1
R Recover/export rules from a backup .PST Using Outlook 2
J Formatting Contacts to Export for iPhone Using Outlook 0
B No export way Using Outlook 4
