Outlook 365 VBA to access "Other Actions" menu for incoming emails in outlook
richardwing
Outlook 365 64 bit
Hello I am looking to add menu item actions into this other actions menu in outlook that would trigger macros that pertain to the specific message being viewed.
Any guidance in the right direction as to what area this is so I can know how to search here or in google for others that may have been looking to customize this area?
JorgeDario restrict access to a certain folder with vba Outlook VBA and Custom Forms 3
F Get details of sent items with Access VBA Outlook VBA and Custom Forms 1
G Applying rules to email generated from MS Access by VBA Using Outlook 6
A Creating and sanding tasks from Access VBA Outlook VBA and Custom Forms 2
R Outlook and Access integration using VBA Outlook VBA and Custom Forms 1
K Outlook admin vs individual access (VBA pulling info) Outlook VBA and Custom Forms 1
S VBA access current contact? BCM (Business Contact Manager) 1
L How do I Run Saved Export in Access 2007 VBA? Outlook VBA and Custom Forms 1
M can't access outlook contacts from excel via VBA Outlook VBA and Custom Forms 4
