Outlook - Macro to block senders domain - Macro Fix
Conan the Barbarian
Outlook 365 64 bit
Hi Mum
I've had problems with spam filters in Outlook for years.
Paid solutions just don't work predictably.
I found this post on a journey to try and fix it: Macro to block senders domain.
I wrote my own fix, and am sharing it here. It will even block entire domains with the click of a button, assuming that it's not in an excluded list.
Now, just add a button on the Home Ribbon and click it when you have proper spam selected - the sender of which you never want to see again - in the junk email folder. You want to wire up the sub named AddtoBlockedSendersandDeleteBlockedJunkEmail()
It will then:
1. add the domain of the email address to the blockedsenders list, unless the domain is in the excluded list - and in that case it will add the email address instead to a custom spam list file; and then
2. parse the blockedsenders lists (builtin and custom list) and delete everything in your Junk folder from all those in either list.
For me, it is so beautiful, it is almost romantic. I'm looking forward to not having to mess around with deficient plugins that move spam from other email accounts into a single folder and having to delete things which I should not even be seeing anymore.
Not thoroughly tested.
Conan
Witzker Macro to move @domain.xx of a Spammail to Blacklist in Outlook 2019 Outlook VBA and Custom Forms 7
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
P Macro to attach a file in a shared Outlook draft folder Outlook VBA and Custom Forms 2
R Macro to check file name with outlook address book Outlook VBA and Custom Forms 0
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
L Outlook 2007 - Macro Re Search Using Outlook 16
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
A newb outlook macro help Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import Contacts and vCards into Outlook Using Outlook 0
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
S Macro in an excel for outlook. Outlook VBA and Custom Forms 2
A Outlook Macro Causing Excel Error Outlook VBA and Custom Forms 0
S Outlook Macro Reply to a message Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import vCards into Outlook Using Outlook 0
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
A Macro to Copy Data from Outlook to Excel Spreadsheet Using Outlook 2
