User Defined Fields_Difference between columns
  • Thread starter Thread starter TonyaG
TonyaG
New to this program and setting up database. Could someone explain to the
difference between the left column and the right column under the user
defined fields?
What's the diff. between a group and a field?
Would greatly appreciate any input that you have.
TNG
"TonyaG" <TonyaG> schreef in bericht
news:80E670A2-E719-4D04-9819-4BBF331CBE76@microsoft.com...
> defined fields?
> Thanks,
> > TNG
User defined fields are placed in the left or the right column of your
screen. :-)
They can also be placed on otrher screens, where they will appear underneath
the (FIXED) fileds use dby BCM
A group is only used for lay-out purposes, no real function but it looks
bettrer on your screen.
I'm very interesetd in how you will come along using BCM
Thanks Jan - appreciate your prompt response. Do you know I apply a user
defined field to an account? I've entered in all of my user defined fields
that i want to use. But now i need to figure out how to apply them to each
accout in my BCM.
Any thoughts you have would be greatly appreciated
TNG
> > defined fields?
> > Thanks,
> > > > TNG
> screen. :-)
news:C529A3E1-38D6-4CE6-B84C-C9DB5D67E214@microsoft.com...
> each
> accout in my BCM.
> Thanks!
As I'm musing a Dutch version, menu items may differ a bit.
- Select an account
- In the menu I've :"Action", "show", "communicate", "" options"
In the "show" menu, select the view you want to add items to (Let's just use
the default, "main")
In the "options" menu, selct adjust form.
Now you can add fields, the fuields will be added to th emain screen, but
maybe you have to scroll down to see them. If you add a field with a name
already in use, BCM will recognize and use teh already existing field.
Jan,
Your information is proving to be beyond helpful! I appreciate it so much.
Just one more question for you. I am starting to understand how to use the
'user defined' fields. However, how do i print out a report using the custom
columns?
I will try and make this as abbrieviated as possible. I have accounts set
up. (We're a landscape architecture firm). I've set up various user defined
fileds to indicate which type of business each account is (architect,
engineer, planner, etc.)
I'm not sure if this is the best way to do it, but as a trial, i went into a
couple of my accounts who i know are architects. at the top of the screen, i
went to the "show" menu, clicked on user defined fields, and then put an "x"
next to the Architect field.
Now i want to print out a report which would include all of our architects.
I cilick on reports, accounts, by category, and then when i go to print out
the report, under "modify report", custom columns and click the box
"architect".
This pulls together a list which a check mark next to all the architects.
however, the $64,000 question is:
is there a way to print up ONLY the architects under this report using the
user defined fields?
i know that's the long winded version of asking that question but if you
have any info that would be greatly appreciate.
Thanks so much!
Tonya
TNG
> > each
> > accout in my BCM.
> > Thanks!
> - Select an account
F MAPI, User Defined Fields and perspective after 20 years Outlook VBA and Custom Forms 0
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
S VBA with User Defined fields Outlook VBA and Custom Forms 9
M Map Outlook user defined fields onto a Sharepoint list ??? Outlook VBA and Custom Forms 1
N How to retrieve user defined fields values to bcm form. Using Outlook 2
N How to disable user defined fields in BCM forms Using Outlook 2
K User Defined Fields in Outlook 2010 Using Outlook 2
P User-Defined Relationship Fields: Invisible? BCM (Business Contact Manager) 0
W Template to produce calendars with wrapped text & user-defined fields? Using Outlook 1
R writing "Instant Search" queries to find User-Defined fields Using Outlook 0
P Joining the User Defined Fields to their User Field&lt;n&gt; counterpart BCM (Business Contact Manager) 0
E Accessing User Defined Fields in BCM Database part 2 BCM (Business Contact Manager) 0
E [SOLVED] Accessing User Defined Fields in BCM Database part 1 BCM (Business Contact Manager) 9
J User Defined Fields Outlook VBA and Custom Forms 6
J user defined fields Outlook VBA and Custom Forms 2
P Where are User-defined fields stored in BCM 2010 database? BCM (Business Contact Manager) 2
M User defined fields Outlook VBA and Custom Forms 6
J User defined fields with pre-defined values Outlook VBA and Custom Forms 3
J Where does BCM store User-Defined fields in the database? BCM (Business Contact Manager) 3
D User-defined fields and multiple forms BCM (Business Contact Manager) 1
T User Defined Fields vs. Area of Interest BCM (Business Contact Manager) 1
C User Defined Fields BCM (Business Contact Manager) 3
Witzker Outlook 2019 How to get a Photo in a User Defined Contact form Outlook VBA and Custom Forms 2
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
Witzker Place cursor at opening, a user defined OL contact form Outlook VBA and Custom Forms 2
R Creating a user defined function Outlook VBA and Custom Forms 3
Daniel Schunk User-defined form arrives empty at the recipient Using Outlook 3
S Outlook User defined date field (UDF) not syncing Using Outlook 2
G how can Apply User-defined Field to all Sub Folder and Other Using Outlook 14
F Adding User Defined Field to another form Using Outlook 0
G How to let data in an account user defined field appear in the same field all related opportunities BCM (Business Contact Manager) 1
V Extracting user-defined details from a public folder Outlook VBA and Custom Forms 2
J How to show the "value" of a user-defined Account field in a Contact Record BCM (Business Contact Manager) 2
Witzker Outlook bug when creating a user defined contact form? Using Outlook 1
Wotme Syntax for user defined field in VBA Using Outlook 1
