User defined fields with pre-defined values
John Bacon
I want a user-defined field in a inbox that will only allow entries from a
pre-defined drop-down list, in the same way that the importance field only
allows values fromlow, normal, high.
Does anyone know how to do this?
Sue Mosher [MVP]
Do you mean you want this field to appear in views of the Inbox folder?
That's not possible. Outlook doesn't support custom drop-downs in views,
only on forms
Sue Mosher
"John Bacon" <JohnBacon> wrote in message
news:EFA25B21-ABCD-49EF-A2F6-7C30F01F8421@microsoft.com...
John Bacon
John Bacon
Well that's a great pity. Thanks anyway.
F MAPI, User Defined Fields and perspective after 20 years Outlook VBA and Custom Forms 0
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
S VBA with User Defined fields Outlook VBA and Custom Forms 9
M Map Outlook user defined fields onto a Sharepoint list ??? Outlook VBA and Custom Forms 1
N How to retrieve user defined fields values to bcm form. Using Outlook 2
N How to disable user defined fields in BCM forms Using Outlook 2
K User Defined Fields in Outlook 2010 Using Outlook 2
P User-Defined Relationship Fields: Invisible? BCM (Business Contact Manager) 0
W Template to produce calendars with wrapped text & user-defined fields? Using Outlook 1
R writing "Instant Search" queries to find User-Defined fields Using Outlook 0
P Joining the User Defined Fields to their User Field&lt;n&gt; counterpart BCM (Business Contact Manager) 0
E Accessing User Defined Fields in BCM Database part 2 BCM (Business Contact Manager) 0
E [SOLVED] Accessing User Defined Fields in BCM Database part 1 BCM (Business Contact Manager) 9
J User Defined Fields Outlook VBA and Custom Forms 6
J user defined fields Outlook VBA and Custom Forms 2
P Where are User-defined fields stored in BCM 2010 database? BCM (Business Contact Manager) 2
M User defined fields Outlook VBA and Custom Forms 6
J Where does BCM store User-Defined fields in the database? BCM (Business Contact Manager) 3
D User-defined fields and multiple forms BCM (Business Contact Manager) 1
T User Defined Fields vs. Area of Interest BCM (Business Contact Manager) 1
C User Defined Fields BCM (Business Contact Manager) 3
Witzker Outlook 2019 Macro GoTo user defined search folder Outlook VBA and Custom Forms 5
Witzker Outlook 2019 How to get a Photo in a User Defined Contact form Outlook VBA and Custom Forms 2
Witzker Outlook 2019 Edit contact from email does not open the user defined contactform Using Outlook 3
Witzker Place cursor at opening, a user defined OL contact form Outlook VBA and Custom Forms 3
R Creating a user defined function Outlook VBA and Custom Forms 3
Daniel Schunk User-defined form arrives empty at the recipient Using Outlook 3
S Outlook User defined date field (UDF) not syncing Using Outlook 2
G how can Apply User-defined Field to all Sub Folder and Other Using Outlook 14
F Adding User Defined Field to another form Using Outlook 0
G How to let data in an account user defined field appear in the same field all related opportunities BCM (Business Contact Manager) 1
V Extracting user-defined details from a public folder Outlook VBA and Custom Forms 2
J How to show the "value" of a user-defined Account field in a Contact Record BCM (Business Contact Manager) 2
Witzker Outlook bug when creating a user defined contact form? Using Outlook 1
Wotme Syntax for user defined field in VBA Using Outlook 1
J How to create a user defined dropdown list field for a custom contact form Using Outlook 3
