Forward E-mails at Certain Times in Outlook using VBA
  • Thread starter Thread starter Hotnumbers2001
H
Hotnumbers2001
Forward E-mails at Certain Times in Outlook to cell phone? Any code
would help. I am very familiar with VB coding in EXCEL. Outlook is my
new adventure.
PLEASE HELP. I have a 10:00 am dedline to give to my boss if this is
possible.
Hotnumbers2001
It's certainly possible. There are also commercial addins that will schedule
emails to be sent on a regular basis, but I don't know if those will forward
messages.
Would this be Outlook VBA code or a COM addin done in VB6 or VB.NET or ...?
You need a timer and some logic as to what emails are to be forwarded. You
can search at www.outlookcode.com for "zaphtml" to find code that will
handle emails being delivered to Inbox. That strips out HTML but can be
adapted to do anything else with those incoming emails including forwarding
them to a specific email address or cell phone if it has an SMTP address.
What sort of timer to use depends on what you have installed in the way of a
development system and how good your coding skills are. For example in VBA
code you can use a Win32 API system timer but that takes tons of obscure
code. If you are coding in VB6 or VB.NET you can use a timer control
provided with that development environment.
This link has code for a VB6 high res timer but can be adapted to work in
VBA code, as one example:
http://www.vbaccelerator.com/home/vb/code/Libraries/HiResTimer/article.asp
"Hotnumbers2001" <Hotnumbers2001.4b5c97f@outlookbanter.com> wrote in message
news:Hotnumbers2001.4b5c97f@outlookbanter.com...
> new adventure.
> possible.
> > Hotnumbers2001
A Forward mails with "FW:" or "RE:" in title Using Outlook 2
A How to forward all e-mails from one address to five (5) other e-mail address? Using Outlook 1
K Reply or forward - some e-mails do not display correctly Using Outlook 3
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
D Outlook 365 Forward Meeting Related Messages to Specific Meeting Organizer Outlook VBA and Custom Forms 0
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
