Reply or forward - some e-mails do not display correctly
Katu
I am using Outlook 2010 for some days and I have problem when forwarding/replyng of specific e-mail. They will get e-mail as shown below. I tried to send same e-mail to differnent accounts and people using different e-mail clients, and problem remain same.
Can anybody tell what should be solution?
Date: Fri, 22 Jul 2011 09:03:14 +0300
Message-ID: <000001cc4835$0b92fa30$22b8ee90$@xxxxxx.xx
MIME-Version: 1.0
Content-Type: multipart/alternative;
boundary="----=_NextPart_000_0001_01CC484E.30E2A330"
X-Mailer: Microsoft Outlook 14.0
Thread-Index: AQI9v2wnh+0TPJ/unTois/Il2wWl8pQU6zXQ
Content-Language: et
This is a multipart message in MIME format.
------=_NextPart_000_002E_01CC484C.FC294820
Content-Type: text/plain;
charset="UTF-8"
Content-Transfer-Encoding: quoted-printable
XXXXX
------=_NextPart_000_0001_01CC484E.30E2A330
Content-Type: text/html;
charset="utf-8"
<html xmlns:v=3D"urn:schemas-microsoft-com:vml" =
etc.....
Does this happen with new messages or replies? The messages are corrupt (that's the easy part) - determining why they are corrupt is the hard part.
Is this something that happens often, so it should be easy to repro? One common cause is antivirus scanners scanning outgoing email. To check, start outlook in safe mode and see if it happens again. If its a frequent thing and you can easily repro it, you'll know fairly quickly if the Safe mode ends the problem - if so, its an addin at fault. (Close Outlook. Hold Ctrl as you click on the Outlook icon to start in Safe mode.)
Katu
Its problem of reply or forward to specific e-mails, actually they are generated by homepage (send form in homepage).
None of problems with e-mail from other addresses or only composing new emails. Shouldn't antivirus programmes create problems in sending other e-mails as well?
may it be homepage provider fault?
Correct, it sounds like its the home page provider that is causing the problem, not outlook or antivirus.
Do they look ok in your inbox before forwarding?
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
S Reply & Forward Date in original message incorrect Using Outlook 2
A Reply/Forward Emails using Mail Merge BCM (Business Contact Manager) 0
J How to Reply or Forward a message and Archive it in same step? Using Outlook 0
S Outlook 2k/2k3 Reply or Forward: Signature image replaced by original sender Using Outlook 3
R OL2010; How to ALWAYS Reply/Forward using HTML? Using Outlook 1
A Outlook 2010 - Want to Have All Email Reply Forward as Rich Test Using Outlook 7
S Outlook 2003 Prefix on reply and forward Using Outlook 1
D Reply/Forward emails go into the Inbox and not to the Sent box. Using Outlook 5
P Reply / forward with a custom form. Outlook VBA and Custom Forms 1
T Re: Form on Reply or Forward Outlook VBA and Custom Forms 7
R Reply,forward error Outlook VBA and Custom Forms 3
S do Reply, Reply to All, Forward programmatically Outlook VBA and Custom Forms 2
P Automatic Greeting "Hello Name," when Reply All is clicked Outlook VBA and Custom Forms 1
W Reply to email Using Outlook 4
ThinkToday Calculate reply time of outlook mail Using Outlook 1
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
E reply Using Outlook 0
evdbogaard Reply with only last message cited Using Outlook 1
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J VBA Run When Reply Outlook VBA and Custom Forms 4
