vba, forms and shared tasks
pjeffers
Form has custom fields (text boxes).
you input number in textbox 1 and number in textbox 2
I have vba that computes the total and inputs in custom text box 3
that works fine,
however on a shared task (users use the same forms with same text boxes)
it will accept the textbox 1 and textbox 2 but will not run the vba code to fill in the total? Is this normal behaviour?
thanks pvj
What VBA event(s) are you using? Show how you're instantiating the parent
object of any event handlers.
Sue Mosher
"pjeffers" <pjeffers.3wptba@no-spam.invalid> wrote in message
news:pjeffers.3wptba@no-spam.invalid...
> that works fine,
> boxes)
> thanks pvj
> > pjeffers
> https://forums.slipstick.com/
if propItem = "txtTransportationIntrinsicTotal" then
val1 = item.UserProperties("txtTransportationIntrinsicTotal").value
val2 = item.UserProperties("txtTransportationExtrinsicTotal").value
valTotal = val1 + val2
item.Userproperties("txtTransportTotal").value = valTotal
It will save val1 and val2, but it will not calculate valTotal on a shared users task
it will work fine on the users own tasks but not on a task shared to him with owner rights.
Sue Mosher
> that works fine,
> boxes)
> thanks pvj
> pjeffers
Is this code behind a custom form? (If so, you're in the wrong forum
outlook.program_forms is the custom forms forum.) If so, then see
http://outlookcode.com/article.aspx?id=67, the section on Forms in Other
Mailboxes.
Sue Mosher
"pjeffers" <pjeffers.3wpvuy@no-spam.invalid> wrote in message
news:pjeffers.3wpvuy@no-spam.invalid...
> *shared users task*
> IT WILL WORK FINE ON THE USERS OWN TASKS BUT NOT ON A TASK SHARED TO
> HIM WITH OWNER RIGHTS.
> >> > that works fine,
> > > boxes)
I never know which forum to go to. I will repost everything over there
Is this code behind a custom form? (If so, you're in the wrong forum --
Mailboxes.
Sue Mosher
> *shared users task*
> > > that works fine,
> > > boxes)
thanks I looked at that link and will test it on my users task.
Thanks again.
Mailboxes.
Sue Mosher
> *shared users task*
> > > that works fine,
> > > boxes)
It now works correctly when he changed it to allow scripts.
thanks
that works fine,
thanks pvj
No need. I was just providing that info for your future reference.
Sue Mosher
"pjeffers" <pjeffers.3wpymy@no-spam.invalid> wrote in message
news:pjeffers.3wpymy@no-spam.invalid...
> 'Sue Mosher [MVP Wrote:
> > ;59835']Is this code behind a custom form? (If so, you're in the wrong
> > forum > > outlook.program_forms is the custom forms forum.) If so, then see
> > Other
> > Mailboxes.
> > > *shared users task*
> > 3
> > >>> >> > that works fine,
> > >> > boxes)
> > vba
> > pjeffers
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
