If loop not running
  • Thread starter Thread starter Mitch
Mitch
Using Outlook 2003, this script runs whne a users clicks a button to submit
emails with attachments with a different frequency.
It basically gets FreqAtt.Value from another text box, LoopCount is used to
count until it reaches FreqAtt.Value. CB1...CB20 are email addresses. They
all check out fine.
I used dialogue boxes before, during and after the IF statement and it
displayes the right values. 1 2, 2 2. But if I used those values, the IF
statement still isn't hit. (The IF statement that adds an attachment to the
email). Without the IF statement the attachments work.
Is there some kind of specific reason an IF wouldn't work here?
Dim LoopCount
LoopCount = 1
For I = 1 To NumberEmails.Value
Set objMail = Application.CreateItem(0)
If CB1.Value = True Then
Set rcpt = objMail.Recipients.Add(CB1.Tag)
If CB2.Value = True Then
Set rcpt = objMail.Recipients.Add(CB2.Tag)
' ... (Code removed, it's all th same IF's all have corresponding End IF.)
If CB19.Value = True Then
Set rcpt = objMail.Recipients.Add(CB19.Tag)
If CB20.Value = True Then
Set rcpt = objMail.Recipients.Add(CB20.Tag)
If CB1 + CB2 + CB3 + CB4 + CB5 + CB6 + CB7 + CB8 + CB9 + CB10 + CB11 +
CB12 + CB13 + CB14 + CB15 + CB16 + CB17 + CB18 + CB19 + CB20 = False Then
MsgBox ("No Emails Selected"), vbOKOnly
objMail.Subject = SubjectLine + " " + CStr(I)
objMail.Body = "Records Management Test Message " + CStr(I)
MsgBox (" LoopValueBefore: " & LoopCount & " " & FreqAtt.Value), vbOKOnly
If FreqAtt.Value = LoopCount Then
Set myAtt = objMail.Attachments
myAtt.Add AttachmentPath.Value
MsgBox (" LoopValue In IF: " & LoopCount & " " & FreqAtt.Value),
vbOKOnly
LoopCount = 0
MsgBox (" LoopValueAfter: " & LoopCount & " " & FreqAtt.Value), vbOKOnly
LoopCount = LoopCount + 1
objMail.Save
objMail.Send
Next I
It appears to me that you're trying to compare LoopCount, a numeric value,
with the string value of a textbox control. You need to convert one or the
other to a compatible format. Either convert LoopCount to a string value or
the textbox value to a numeric value.
"Mitch" <Mitch> wrote in message
news:7B6C12A0-FB06-4CD1-97B4-0DB279AFA1B0@microsoft.com...
> submit
> to
> all check out fine.
> the
> Dim LoopCount
> LoopCount = 1
> End If
> End If
> End If
> End If
> End If
> vbOKOnly
> vbOKOnly
> LoopCount = 0
> End If
> vbOKOnly
> objMail.Save
> objMail.Send
> Next I
A ItemAdd on Imap Folder get endless loop after saving item Using Outlook 5
W Broken Folder Loop - Outlook 2007 (.oft files) Using Outlook 2
Forum Admin Endless loop when to the new Outlook Connector Using Outlook.com accounts in Outlook 0
S Business Contact Manager (BCM) causing Outlook crash loop BCM (Business Contact Manager) 3
K loop through distribution group (and potentially, embedded DGs) by Outlook VBA and Custom Forms 1
H For Each loop not getting all Email Items Outlook VBA and Custom Forms 3
S Loop mail items within a Custom Search Folder Outlook VBA and Custom Forms 1
M Outlook VBA Form not finding FOR LOOP -- Error message Outlook VBA and Custom Forms 2
R Loop Attachment (once again) Outlook VBA and Custom Forms 6
H running multiple macros at once Outlook VBA and Custom Forms 0
F Running Scripts in Outlook 2021 Using Outlook 0
Diane Poremsky OUTLOOK.EXE continues running after you exit Outlook Using Outlook 0
Diane Poremsky Running Outlook Macros on a Schedule Using Outlook 0
G email returns after running macro to move emails Outlook VBA and Custom Forms 1
N Running multiple macros upon sending Outlook VBA and Custom Forms 6
G Error when running scanpst.exe Using Outlook 1
V Running scripts with Outlook 2013 Using Outlook 17
D Stopping "do you want to continue running scripts on this page" warnings Using Outlook 4
M Running macros in tasks sent out as meeting requests in invitees machine Using Outlook 4
N Rules stop running automatically Using Outlook 10
M Why rules stop running automatically? Using Outlook 1
L remove a hotmail account from Outlook 2007 running on Vista home premium Using Outlook.com accounts in Outlook 1
A running code after the new inspector is visible Outlook VBA and Custom Forms 1
M Running Outlook as Scheduled task Outlook VBA and Custom Forms 1
S ActiveExplorer return NULL on new Window user login and running Outlook first time Outlook VBA and Custom Forms 19
A Running Code in Side by side calendar view Outlook VBA and Custom Forms 2
