Running Code in Side by side calendar view
  • Thread starter Thread starter Adrian Miller
Adrian Miller
I've published a custom form in global forms library and define this form as
default form for my teammate's calendar. The custom forms uses code. If I
create a new appointment in my teammate's calendar using the Outlook side by
side calendar view the custom form is displayed, however the code is not
running.
Is there a way to get the code running?
Thanks for any advice
Adrian
Adrian Miller
Make the necessary change in setting described at
http://outlookcode.com/article.aspx?id=67
Sue Mosher
"Adrian Miller" <adrian.miller@hotmail.com> wrote in message
news:u7FcrxcoKHA.5696@TK2MSFTNGP04.phx.gbl...
> Hi,
> as default form for my teammate's calendar. The custom forms uses code. If
> I create a new appointment in my teammate's calendar using the Outlook
> side by side calendar view the custom form is displayed, however the code
> is not running.
> Adrian
> > Adrian Miller
Hi Sue,
excellent! Great help!
Adrian
Adrian Miller
"Sue Mosher [MVP]" <suemvp@gmail.com> wrote in message
news:%23aqBJJdoKHA.5464@TK2MSFTNGP02.phx.gbl...
> > Sue Mosher
> > Hi,
> > If I create a new appointment in my teammate's calendar using the Outlook
> > is not running.
> > Adrian
>> > > Adrian Miller
A running code after the new inspector is visible Outlook VBA and Custom Forms 1
N Running Code before Access 2007 closes down Outlook VBA and Custom Forms 1
H running multiple macros at once Outlook VBA and Custom Forms 0
F Running Scripts in Outlook 2021 Using Outlook 0
Diane Poremsky OUTLOOK.EXE continues running after you exit Outlook Using Outlook 0
Diane Poremsky Running Outlook Macros on a Schedule Using Outlook 0
G email returns after running macro to move emails Outlook VBA and Custom Forms 1
N Running multiple macros upon sending Outlook VBA and Custom Forms 6
G Error when running scanpst.exe Using Outlook 1
V Running scripts with Outlook 2013 Using Outlook 17
D Stopping "do you want to continue running scripts on this page" warnings Using Outlook 4
M Running macros in tasks sent out as meeting requests in invitees machine Using Outlook 4
N Rules stop running automatically Using Outlook 10
M Why rules stop running automatically? Using Outlook 1
L remove a hotmail account from Outlook 2007 running on Vista home premium Using Outlook.com accounts in Outlook 1
M Running Outlook as Scheduled task Outlook VBA and Custom Forms 1
S ActiveExplorer return NULL on new Window user login and running Outlook first time Outlook VBA and Custom Forms 19
G Re:Running a Macro when email arrives Outlook VBA and Custom Forms 1
D Running a Program from Custom Action Rule Outlook VBA and Custom Forms 1
B Phantom VBA Running Outlook VBA and Custom Forms 1
M If loop not running Outlook VBA and Custom Forms 1
D Troubleshooting rule/script not running Outlook VBA and Custom Forms 5
P How to use a form from a rule running on the inbox Outlook VBA and Custom Forms 1
Q Running the Database from a Server BCM (Business Contact Manager) 7
S Outlook rules not running automatically Using Outlook 11
