Troubleshooting rule/script not running
  • Thread starter Thread starter Dawn
Dawn
I created a rule that looks for certain conditions in the email, and then
runs a script. Worked lovely yesterday. This morning, it will not run. Any
suggestions for troubleshooting why? [BTW, Sue Mosher helped me out with the
same script yesterday (thanks!) but thought I'd start a new post since this
is a different problem I'm having.]
I think I've narrowed it down to a problem with the script itself not
running, because I tried copying the rule, and then instead of having it run
the script, had the rule just forward the message to myself again. This
worked fine. My other rules seem to be working fine.
The script is saved in the ThisOutlookSession window, and all looks fine as
far as I can tell, it's all still there. I did try making some changes to
the script itself this morning before testing the rule, but when it didn't
work, I changed everthing back to original script and it still doesn't work.
Also tried closing & reopening Outlook, and also restarting the whole darn
computer.
This is the first time I've ever tried running scripts from rules -- is this
a tempremental operation perhaps? Thanks for any ideas.
Does other VBA code run? Have you checked your macro security setting?
Sue Mosher
"Dawn" <dawn@NOSPAMstofoco.com> wrote in message
news:5601A4DA-F6FD-41F9-837E-37CF490DABBC@microsoft.com...
> Any
> the
> this
> run
> as
> work.
> computer.
> this
Hi Sue -- it seems I can't get any script to fire from this rule. I added a
script to change the message to plain text, it also won't run. My security
settings were on "warning for signed macros, disable unsigned macros" I
tried setting it to "warnings for all macros" and to "no security check"
neither of which helped. I've set it back to "warnings for all". It did
work yesterday, nothing's changed as far as I know.
> > Sue Mosher
> > Any
> > the
> > this
> > run
> > as
> > work.
> > computer.
> > this
We already know from your description that the rule script isn't running,
but what about a simple VBA macro?
FYI, you must restart Outlook after changing the macro security setting or
the new setting won't take effect.
Sue Mosher
news:D394F055-AE4A-4063-9C37-456218E46307@microsoft.com...
> a
> security
> > >then
> > > run.
> > > Any
> > > with
> > > the
> > > this
> > > it
> > > run
> > > This
> > > fine
> > > as
> > > to
> > > didn't
> > > work.
> > > darn
> > > computer.
> > > this
Thanks, Macro security did turn out to be the problem. (I didn't understand
the difference between a script and a macro, AND I didn't know I needed to
restart to get the settings change to take effect.)
(now... guess I have to figure out how to digitally sign the script, or put
up with that warning box!)
Thanks for your help, appreciate it!
> > Sue Mosher
> > a
> > security
> >> >then
> >> > run.
> >> > Any
> >> > with
> >> > the
> >> > this
> >> > it
> >> > run
> >> > This
> >> > fine
> >> > as
> >> > to
> >> > didn't
> >> > work.
> >> > darn
> >> > computer.
> >> > this
FWIW, there are no "scripts" in VBA. It's a bad terminology choice on
Microsoft's part.
Sue Mosher
news:7B595010-9D1A-4DEE-A09B-2686E47F55A8@microsoft.com...
> understand
> put
> > or
>> > > Sue Mosher
> > > added
> > > a
> > > security
> > > I
> > > check"
> > > did
> > >> >then
> > >> > run.
> > >> > Any
> > >> > with
> > >> > the
> > >> > since
> > >> > this
> > >> > not
> > >> > having
> > >> > it
> > >> > run
> > >> > This
> > >> > fine
> > >> > as
> > >> > changes
> > >> > to
> > >> > didn't
> > >> > doesn't
> > >> > work.
> > >> > whole
> > >> > darn
> > >> > computer.
> > >>> >> > This is the first time I've ever tried running scripts from rules > > >> > is
> > >> > this
J Outlook troubleshooting/logging - option grayed out Using Outlook 2
Sarge USMC troubleshooting slow startup Using Outlook 6
J Troubleshooting Creating New Outlook Account Using Outlook 1
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 4
CWM330 This rule has a condition that the server cannot process? Using Outlook 1
A rule name into message - how? Outlook VBA and Custom Forms 5
A manual rule sends mail to wrong folder Using Outlook 5
bhamberg Finding a rouge rule... Using Outlook 6
D How to get this rule to work Using Outlook 0
R Rogue Outlook Rule ? Using Outlook 2
L Making rule to move email to folder from one O365 domain Using Outlook 1
