running code after the new inspector is visible
  • Thread starter Thread starter Alberto
Alberto
Hello I would like to execute some code after showing a new inspector. But I
don't want to run this code within the NewInspector event but after the Item
is visible and I don't know how. The code doesn't take so long but I wouldn't
like the user waits 2 Seconds until this operation is done.
Any ideas?
Using Outlook 2003
Use the first Inspector.Activate() event to do what you want.
"Alberto" <Alberto> wrote in message
news:59C0BF38-B786-4C8D-B4C3-74A3A7F1211B@microsoft.com...
> I
> Item
> wouldn't
> Any ideas?
> Using Outlook 2003
> Thanks
A Running Code in Side by side calendar view Outlook VBA and Custom Forms 2
N Running Code before Access 2007 closes down Outlook VBA and Custom Forms 1
H running multiple macros at once Outlook VBA and Custom Forms 0
F Running Scripts in Outlook 2021 Using Outlook 0
Diane Poremsky OUTLOOK.EXE continues running after you exit Outlook Using Outlook 0
Diane Poremsky Running Outlook Macros on a Schedule Using Outlook 0
G email returns after running macro to move emails Outlook VBA and Custom Forms 1
N Running multiple macros upon sending Outlook VBA and Custom Forms 6
G Error when running scanpst.exe Using Outlook 1
V Running scripts with Outlook 2013 Using Outlook 17
D Stopping "do you want to continue running scripts on this page" warnings Using Outlook 4
M Running macros in tasks sent out as meeting requests in invitees machine Using Outlook 4
N Rules stop running automatically Using Outlook 10
M Why rules stop running automatically? Using Outlook 1
L remove a hotmail account from Outlook 2007 running on Vista home premium Using Outlook.com accounts in Outlook 1
M Running Outlook as Scheduled task Outlook VBA and Custom Forms 1
S ActiveExplorer return NULL on new Window user login and running Outlook first time Outlook VBA and Custom Forms 19
G Re:Running a Macro when email arrives Outlook VBA and Custom Forms 1
D Running a Program from Custom Action Rule Outlook VBA and Custom Forms 1
B Phantom VBA Running Outlook VBA and Custom Forms 1
M If loop not running Outlook VBA and Custom Forms 1
D Troubleshooting rule/script not running Outlook VBA and Custom Forms 5
P How to use a form from a rule running on the inbox Outlook VBA and Custom Forms 1
Q Running the Database from a Server BCM (Business Contact Manager) 7
S Outlook rules not running automatically Using Outlook 11
