running multiple macros at once
holleymc
Outlook 365 32 bit
Outlook version:     Outlook 365
Hello all! I have two macros that I would like to combine into a single step. Macro 1is opens a template, paste the clipboard contentes into the body of the template. Macro 2 copies the email address from the body of hte email and paste it into the To field of the email. Each of these work great individually, but I cannot even do a simple "call" for these two to work together. Any suggestions?
One other tweak I would like to make is for it to copy the Customer # and past it within the subject line of the email, but if that never happens, if I could just get the first two to work together, that would be be most appreciated!
I would greatly appreciate any suggestions!
This is the two codes:
Macro 1
Dim MyItem As Outlook.MailItem
Dim str_jpeg_file As String
Dim wdDoc As Object
Dim oRng As Object
    'On Error Resume Next
    Set OutApp = GetObject(, "Outlook.Application")
    If Err <> 0 Then Set OutApp = CreateObject("Outlook.Application")
    On Error GoTo 0
    'Set OutMail = OutApp.CreateItem(0)
    Set MyItem = Application.CreateItemFromTemplate("C:\Users\user2\Documents\Customer Statement .msg")
    MyItem.Display
    With MyItem
        .BodyFormat = 2
       ' .To = ""
       ' .CC = ""
        '.BCC = ""
        .Subject = "Customer Statement "
SendKeys "{right}{down}^({v})", True
Macro 2
Sub ReadMsg2()
'Graham Mayor - https://www.gmayor.com - Last updated - 06 Jul 2024
Dim olMsg As MailItem
    Select Case Outlook.Application.ActiveWindow.Class
        Case olInspector
            Set olMsg = ActiveInspector.CurrentItem
        Case olExplorer
            Set olMsg = Application.ActiveExplorer.Selection.Item(1)
   GetAddress olMsg
lbl_Exit:
    Set olMsg = Nothing
Sub GetAddress(olItem As MailItem)
Dim olInsp As Outlook.Inspector
Dim wdDoc As Object
Dim oRng As Object
Dim oAddr As Object
Dim hLink As Object
    With olItem
        Set olInsp = .GetInspector
        Set wdDoc = olInsp.WordEditor
        Set oRng = wdDoc.Range
        With oRng.Find
            Do While .Execute(findText:="Sincerely")
                Set oAddr = oRng
                Exit Do
            Loop
        If Not oAddr Is Nothing Then
            oAddr.collapse 1
            oAddr.MoveStartUntil "@", -1073741823
            Set oAddr = oAddr.Paragraphs(1).Range
                olItem.To = oAddr.Text
                oAddr.Text = ""
lbl_Exit:
    Set olInsp = Nothing
    Set wdDoc = Nothing
    Set oRng = Nothing
    Set oAddr = Nothing
N Running multiple macros upon sending Outlook VBA and Custom Forms 6
F Running Scripts in Outlook 2021 Using Outlook 0
Diane Poremsky OUTLOOK.EXE continues running after you exit Outlook Using Outlook 0
Diane Poremsky Running Outlook Macros on a Schedule Using Outlook 0
G email returns after running macro to move emails Outlook VBA and Custom Forms 1
G Error when running scanpst.exe Using Outlook 1
V Running scripts with Outlook 2013 Using Outlook 17
D Stopping "do you want to continue running scripts on this page" warnings Using Outlook 4
M Running macros in tasks sent out as meeting requests in invitees machine Using Outlook 4
N Rules stop running automatically Using Outlook 10
M Why rules stop running automatically? Using Outlook 1
L remove a hotmail account from Outlook 2007 running on Vista home premium Using Outlook.com accounts in Outlook 1
A running code after the new inspector is visible Outlook VBA and Custom Forms 1
M Running Outlook as Scheduled task Outlook VBA and Custom Forms 1
S ActiveExplorer return NULL on new Window user login and running Outlook first time Outlook VBA and Custom Forms 19
A Running Code in Side by side calendar view Outlook VBA and Custom Forms 2
G Re:Running a Macro when email arrives Outlook VBA and Custom Forms 1
D Running a Program from Custom Action Rule Outlook VBA and Custom Forms 1
B Phantom VBA Running Outlook VBA and Custom Forms 1
M If loop not running Outlook VBA and Custom Forms 1
D Troubleshooting rule/script not running Outlook VBA and Custom Forms 5
P How to use a form from a rule running on the inbox Outlook VBA and Custom Forms 1
Q Running the Database from a Server BCM (Business Contact Manager) 7
N Running Code before Access 2007 closes down Outlook VBA and Custom Forms 1
S Outlook rules not running automatically Using Outlook 11
A Free add-in solution: multiple calendars in the Todo pane Using Outlook 0
C Multiple accounts on Outlook.com? Using Outlook 3
