forward with header gufff etc
  • Thread starter Thread starter Maxx
Maxx
I'd like to be able to forward a message in Outlook 2003 without all the
header business that Outlook ads. That is to say I would like to be able to
forward a message in a way that the recipient has no clue that the message
was forwarded.
Is this possible with VBA?
Create a new message and insert just the body.
Best regards
Michael Bauer
Am Sat, 19 Sep 2009 16:27:50 +1000 schrieb Maxx:
to
> was forwarded.
ok
thank you
"Michael Bauer " <mb@mvps.org> wrote in message
news:126wft04ixjcm.1b9tawigmflce.dlg@40tude.net...
> > Best regards
> Michael Bauer
> to
> > message
> > was forwarded.
M Simple Reply, Reply All, Forward Outlook VBA and Custom Forms 1
A Forward mails with "FW:" or "RE:" in title Using Outlook 2
J Outlook 365 Forward Email Subject to my inbox when new email arrive in shared inbox Using Outlook 0
D Outlook 365 Forward Meeting Related Messages to Specific Meeting Organizer Outlook VBA and Custom Forms 0
T Customized form: The Forward option shows write layout Outlook VBA and Custom Forms 0
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
