How to input text at the beginning of the body of a message.
Mr. GetRight
Need a little help.
I'm using Outlook 2003, trying to make a macro that inputs a set statment in
the body of a message. I got it to do it but the problem is my statement
needs to be in front of the attachment that is already in the message but it
keep going behind it. Also for some reason it is removing the first letter
from my statment. I copy and pasted the main parts of it below, ...
Option Explicit
Public icn As String
Public myOlApp As New Outlook.Application
Public myEmail As Object
Public myAttachment As Object
Sub FormateEmail()
Set myEmail = myOlApp.ActiveInspector.CurrentItem
Set myAttachment = myEmail.Attachments
myEmail.To = "email@someplace.com"
myEmail.Subject = "Subject Line"
myEmail.Body = "output statement 1=" + icn + " Output statement2"
Michael Bauer
As your example completely overwrites the body of the message, there's no
reason to see how anything else could be there - except it's an rtf
message, in that case you need to set the position of the attachment(s).
Best regards
Michael Bauer
G Outlook forms text input Outlook VBA and Custom Forms 1
C Why does Outlook (desktop) 365 for Windows keep making me input my passwords? Using Outlook 12
Marc2019 Cannot input Vietnamese Characters on my MSOutlook 2016 in Windows 7 Using Outlook 0
S Ask user to input email template through VBA Outlook VBA and Custom Forms 1
K Reducing data input, how to auto-fill Account form info into Contact form BCM (Business Contact Manager) 0
T Including Field Input as Subject Line Outlook VBA and Custom Forms 1
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 6
J Outlook 365 Emails showing as links and text only Using Outlook 4
J Text icon in Quick Access toolbar ? Using Outlook 2
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
S Unable to extract text from an Outlook email message Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
S Outlook to check for specific text Outlook VBA and Custom Forms 3
B Paste formatted text (bold, underlined and in quotes) Outlook VBA and Custom Forms 1
N Is there an Outlook tool to normalize text for entries that are in ALL CAPS? Using Outlook 2
