Copy specific email body text
zzecevic
Outlook 365 64 bit
Hi all,
When I receive new email, I need to copy email body text that is between specific two words, like copy text from Hello work to Kind regards word. Email body also, most of the times, contains table.
Can someone help me with this?
Thank you in advance!
S VBA to identify a specific email and copy the attachment from it to the network Outlook VBA and Custom Forms 4
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
I How to make a copy of a task Using Outlook 8
F copy data in Custom Field to other folder Outlook VBA and Custom Forms 2
