How to launch macro within a rule?
  • Thread starter Thread starter mntn-biker
mntn-biker
Newbie here and have virtually no vba experience but have a hopefully
simple question. Is it possible to launch a macro within a rule in
Outlook 2003? Here is the macro that I want to launch when I receive an
e-mail from a customer:
Sub txtmsgfw()
Dim msg As Outlook.MailItem
Set msg = Application.CreateItem(olMailItem)
msg.Subject = "Email from Customer"
msg.Display
Set msg = Nothing
I am using the rule to create a new simple e-mail message that I can
have forwarded to my cell phone as a text message. I cannot simply use
forwarding since some e-mails from my customers have 8mb attachments and
those don't fly. I don't see anyplace within the rules that can launch
a macro unless I am missing it.
Thanks - Mike
mntn-biker
----------------------------------------mntn-biker's Profile: userid=312
?t=96641
There's just a simple change necessary as the rule needs to pass the mail
from the customer the the rule:
Sub txtmsgfw(Mail As Outlook.MailItem)
msg.Display
Set msg = Nothing
Best regards
Michael Bauer
Am Thu, 14 May 2009 16:43:36 +0100 schrieb mntn-biker:
> Sub txtmsgfw()
> msg.Display
> Set msg = Nothing
> End Sub
> Thanks - Mike
'Michael Bauer [MVP - Outlook Wrote:
> ;345545']There's just a simple change necessary as the rule needs to
> pass the mail
> msg.Display
> Set msg = Nothing
> End Sub
> > Best regards
> Michael Bauer
> hopefully
> an
> > Sub txtmsgfw()
> > msg.Display
> > Set msg = Nothing
> > End Sub
> use
> and
> launch
> > Thanks - Mike
Maybe I am missing something but shouldn't I be selecting something
from within this window to get my original macro to launch?
[image: http://www.premiertooldesign.com/images/tech/ol2003rule.gif]
mntn-biker
?t=96641
Excactly. If the shown script is in the ThisOutlookSession module, you
should be able to select it.
Best regards
Michael Bauer
Am Thu, 14 May 2009 18:37:25 +0100 schrieb mntn-biker:
> > pass the mail
> > msg.Display
> > Set msg = Nothing
> > End Sub
>> > > Best regards
> > Michael Bauer
> > hopefully
> > an
>>> Sub txtmsgfw()
> >> msg.Display
> >> Set msg = Nothing
> >> End Sub
> > use
> > and
> > launch
>>> Thanks - Mike
Michael - Thanks for your help and patience thus far. I have attempted
to paste the code into ThisOutlookSession (please see image below).
When I click on script in the rule window, nothing shows up here. I
have changed the macro security to medium. Do I not have something
correct in the ThisOutlookSession window?
[image: http://www.premiertooldesign.com/images/tech/ol2003rule2.gif]
mntn-biker
?t=96641
Delete the code from modul1, and turn the code in ThisoutlookSession from
Private to Public. Does that help?
Best regards
Michael Bauer
Am Fri, 15 May 2009 19:05:42 +0100 schrieb mntn-biker:
Michael - Thanks! That got me thru that first part. Now I have been
messing with adding a recipient and making it send. Here is my code
(that does not work - see image below):
Public Sub txtmsgfw(Mail As Outlook.MailItem)
Dim Recip As Outlook.Recipient
msg.Subject = "Email from customer"
Set Recip = .Recipients.Add("myname@domain.com")
Recip.Type = olTo
For Each Recip In .Recipients
If Not Recip.Resolve Then
msg.Display
Set msg = Nothing
> Send
Any ideas?????
Thanks again for your help! I have been able to read thru the code to
understand what it is doing however, I am not sure where to find the
objects at so I have been googling like crazy and finding bits and
pieces for my puzzle.
Error message:
[image: http://www.premiertooldesign.com/images/tech/olrule3.gif]
mntn-biker
?t=96641
this should do it:
Set Recip = msg.Recipients.Add("myname@domain.com")
Recip.Type = olTo
If msg.Recipients.ResolveAll=False Then
msg.Display
msg.Send
Best regards
Michael Bauer
Am Sat, 16 May 2009 20:40:03 +0100 schrieb mntn-biker:
> Recip.Type = olTo
> msg.Display
> Set msg = Nothing
> End If
> Next
> .Send
> End Sub
> Any ideas?????
> Error message:
Michael - Thanks a million for your help! I did get an error with the
above code and tweaked it a little to get it to work. Here is what I
wound up with:
Set Recip = msg.Recipients.Add("myphonenumber@mywirelessphoneco.com")
Recip.Type = olTo
msg.Display
msg.Send
Now the only thing I need to do to test it is to wait for my texting to
come back online on my phone......
Thanks again - Mike
mntn-biker
?t=96641
D Launch Outlook showing only selected messages. Using Outlook 1
F Launch Marketing Campaign Error BCM (Business Contact Manager) 7
T How to Cancel a queued addon installation on Outlook2003 Launch Outlook VBA and Custom Forms 1
H want to launch outlook with attachemnet for new mail with c# code Outlook VBA and Custom Forms 3
