Macro mode
lgnfox
Good whatever time of day it is where you are.
I’m codding VBA macro in Outlook that processes received Emails and trying to foresee possible bugs. When I was thinking the question came up: Would VBA macro in Outlook run in consecutive or parallel order if some Emails were received simultaneously. Can I change consecutive mode to parallel mode using settings of Outlook?
P Categorise emails on sending - macro not working in Preview mode Using Outlook 1
