Outlook Stationary Font Formating Problem
WmS
I've successfully created an Outlook stationary template, but the font size keeps going to 11pts whenever I create a new email using this stationary. I've looked at my default font settings and they appear to be at 14pts, which is what I would like as a default. This has become very frustrating. Any help??
Additional detail: The custom stationary I created has a background image that was inserted using the COLOR option method. Also, I am using a signature for this stationary. A pecularity is whenever I create a new message, I see 4 lines above my signature. All of those lines are set to 11pts. I never created those lines anywhere, either in the stationary itself or the signature file.
In a new message without stationery, is that the same font used for the message text? If so, it's using the default font settings. Is the default something like Font Name (+Body) or just Font Name?
Without stationary (or signature) the font is Calibri, 14pts. No +Body designation. Interesting thing too is when I have the stationary applied, 4 blank lines show up above the signature. They come up as follows:
Line 1 = Calibri (body) 11 pts
Line 2 = Calibri 14 pts
Line 3 = Calibri 14 pts
Line 4 = Calibri (body) 11 pts
I never inserted these lines to my knowledge and have no way to remove them... unless I remove the stationary, of course. If I apply signatures, it seems to maintain the 14pt and only adds 2 lines above the signature, which is fine. I'm just wondering why when I apply the stationary, it adds two more lines (one above and one below), both @ 11pts.
It's obviously the stationery. :)
do you use 14 pt for everything? if so, you need to set the body format to that.
See Understanding Fonts and the +Body Style - Slipstick Systems - short version is:
1. open a new message form
2. switch to the Format text tab
3. expand the Change Style button
4. choose your preferred fonts (and colors & spacing, if desired)
5. when finished, click on Set as Default
Now every that uses the body format will be 14 pt. I'd also go into Font setting (Control panel, mail, stationery & fonts) and set +body as the default.
I have to tell you, I've done what you recommend and I'm still getting extra lines above the signature line of various font size. I even deleted the stationery and signature I created and started fresh. Now I have 5 blank lines above the signature. I used to have 4. It's frustrating. I KNOW there are no lines at all when I created the stationery, but they sure appear with every instance of a new message. Something is doing this. Maybe I'm doing something, but I'm really at a loss. Any help is appreciated.
I opened the HTML file in Notepad and checked the coding.
Two things affected it:
The default font was set to 11 pt.
 /* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-unhide:no;
	mso-style-qformat:yes;
	mso-style-parent:"";
	margin:0in;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:11.0pt;
	font-family:"Calibri","sans-serif";
And at the bottom, there were 3 lines in the stationary. The middle one is 'correct' but all 3 can be deleted, leaving just
<div class=WordSection1
</div
<p class=MsoNormal style='mso-layout-grid-align:none;text-autospace:none'><span
style='mso-ascii-font-family:Calibri;mso-hansi-font-family:Calibri;mso-bidi-font-family:
Calibri;color:black'><o:p> </o:p></span></p
<p class=MsoNormal><o:p> </o:p></p
<p class=MsoNormal><span style='font-size:14.0pt;mso-bidi-font-size:11.0pt;
mso-ascii-font-family:Calibri;mso-hansi-font-family:Calibri'><o:p> </o:p></span></p
</div
S automate outlook stationary Outlook VBA and Custom Forms 1
N create stationary in outlook Outlook VBA and Custom Forms 1
S Volunteer request: opening invented MSG files in Outlook for Windows Using Outlook 0
A How to Convert an Orphaned OST File Without Outlook or Exchange? Using Outlook 3
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 6
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 5
B Sync Google Calendar with Outlook Using Outlook 5
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
W New Outlook PEOPLE blank Using Outlook 6
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
