Where to post code in Outlook
Heather
I have been reading for days and I can;t find the information. I want to add code for item_send. I see plenty of example, but I know I need to "watch for a trigger" and the "execute event". I put it in quotes becasue I am not quite sure of the terms. Anyway, some code I find say place in class module, some in the "ThisOutlookSession", so how do I call the code that I find listed here ? What goes in ThisOutlookSession and what goes in class modules and why ?
Heather F
ThisOutlookSession is a class module, and it's the place you should use as a beginner. It must be a class module instead of a standrd module because the latter cannot handle events. Don't use quotes, simply paste the code you've found.
The ItemSend event belongs to the Application object, which is already "available". It will be called automatically by Outlook, when you hit the Send button.
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 10
G Outlook Contact Item.Restrict where FullName is NULL Outlook VBA and Custom Forms 3
J OUTLOOK 2016 FILE STORAGE WHERE COMMAND Using Outlook 12
C Long List Of Outlook 2016/Outlook.com Bugs // Where To Report? Using Outlook 10
S Views ans Where Settings AreSavd Using Outlook 4
F Move mails from Deleted Items folder back to its original folder where the mails got deleted Using Outlook 0
Horsepower Where did Evenote come from? Using Outlook 6
tswatek Issue with where Outlook saves new contacts Using Outlook 3
snissen Where is "Edit Message" in Outlook 2016? Using Outlook 2
Mark Foley Where are Outlook categories save for IMAP? Using Outlook 12
T Where did my categorized emails go? Using Outlook 1
P Where are the cached emails stored? Using Outlook.com accounts in Outlook 2
R Outlook 2013 People Pane - Where is the "Add" button for social networks? Using Outlook 4
J Lost contacts.pst afer sync with iCloud: where has contact.pst disapperaed to? Using Outlook 3
O Outlook 2013 contacts - Where to find "Display as"-field Using Outlook 2
J Linking Contacts to a Message Where the Contact isn't an Addressee Using Outlook 1
L How do i choose where i file my sent messages? Using Outlook 1
C Outlook 2007 Contact Card opens in margin of screen where I can't see it Using Outlook 3
P Where the heck is the data? Using Outlook 10
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
B Can't locate in Outlook custom form where is message from Using Outlook 4
B help: where are outlook2000 email accounts stored Using Outlook 14
Rupert Dragwater Where to find folders in Outlook 2010 Using Outlook 4
S Where is the BCM SDK?? BCM (Business Contact Manager) 1
B Where are my emails that I already? Using Outlook 1
G Where are Saved Reports physically stored? BCM (Business Contact Manager) 0
O Where is Launcher, the custom action for Exchange server? Exchange Server Administration 1
J Where is Final Release BCM 2010, Microsoft? Why is Dev Team silent BCM (Business Contact Manager) 2
B Where is RTM version of BCM 2010? BCM (Business Contact Manager) 2
N Where have all the helpful people gone in this forum? BCM (Business Contact Manager) 3
S Custom Fields - Deleting And Where Are They Saved Outlook VBA and Custom Forms 8
M WHERE without using CASE Outlook VBA and Custom Forms 3
S Where to publish my custom form ? Outlook VBA and Custom Forms 4
P Where are User-defined fields stored in BCM 2010 database? BCM (Business Contact Manager) 2
E Where is Business Contact Manager?? BCM (Business Contact Manager) 2
T Where is "administrative groups" Exchange Server Administration 9
D Where does Outlook store signatures? Outlook VBA and Custom Forms 9
K Get folder path where an account stores messages Outlook VBA and Custom Forms 5
A COM add-in causes Outlook 2007 to periodically crash where it did not in Outlook 2003 Outlook VBA and Custom Forms 3
