Check for attachment code not working
Alan McGowan
Outlook 2013 64 bit
I am using the code below to check for missing attachments after you hit the send button. If no attachments are found and you choose yes from the msgbox then a userform loads and all it well. However, if you press no in the msg box what I want to happen is that you are returned back to the email message. At present if you press no the email is sent regardless. Any suggestions?
If UserForm1.TextBox4.Value = "YES" Then
Dim lngAns As Long
Dim varArray As Variant
Dim strWordFound As String
varArray = Array("Attached", "Attach", "Enclosed", "Enclose")
For lngCount = LBound(varArray) To UBound(varArray)
If InStr(1, Item.Body, varArray(lngCount), vbTextCompare) Or InStr(1, Item.Subject, varArray(lngCount), vbTextCompare) Then
strWordFound = strWordFound & "," & varArray(lngCount)
strWordFound = Mid(strWordFound, 2)
If Len(strWordFound) > 0 And Item.Attachments.Count = 0 Then
If MsgBox("You mention attachments but none were found. Do you want to send the mail anyway?", _
vbYesNo + vbQuestion, "Attachment Missing") = vbYes Then
If UserForm1.TextBox2.Value = "YES" Then
UserForm3.Show
All now working using the code below:
Dim lngAns As Long
vbYesNo + vbQuestion, "Email Attachment Missing") = vbYes Then
UserForm3.Show
Cancel = True
Else: UserForm3.Show
ElseIf UserForm4.TextBox2.Value = "YES" Then UserForm3.Show
R Outlook Custom form check if there an attachment Outlook VBA and Custom Forms 2
CWM330 Saving Data: Don't check certain folders Using Outlook 2
Victor.Ayala Automated way to check the option "Show this folder as an email Address Book" Outlook VBA and Custom Forms 2
D Spell check Outlook VBA and Custom Forms 3
L Spell-check dictionary confusion Using Outlook 0
S How to export urls from email to excel and check the status of the url ? Using Outlook 5
S Outlook to check for specific text Outlook VBA and Custom Forms 3
A Check for words in subject header before sending email Outlook VBA and Custom Forms 4
I Check if sent email has been replied Outlook VBA and Custom Forms 1
R Macro to check file name with outlook address book Outlook VBA and Custom Forms 0
Diane Poremsky Check Contacts before moving them to Hotmail Contacts folder Using Outlook 0
Diane Poremsky Check for missing attachments before sending a message Using Outlook 1
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
K check for sender, follow to my personal adress and delete the sent folder. Outlook VBA and Custom Forms 1
J Send and Receive Button - only check default account? Using Outlook 1
Diane Poremsky Check Message Size Before Sending Using Outlook 0
B Check for different domains macro to be triggered by specific domains only Outlook VBA and Custom Forms 2
V Check/convert to emailaddresses Outlook VBA and Custom Forms 11
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
O Unable to check name. Using Outlook 3
L Trying to check for the absence of mail. Outlook VBA and Custom Forms 1
S Check if two organisition is added then i have to give managers passward creteria to send mail Using Outlook 1
Peter H Williams check for new email automaticlly Using Outlook 12
C Unusual Signature & Spell Check Query Using Outlook 1
M Calendar navigation displays previous field records.check calendar is shared.. Using Outlook 3
A Can Rule Check Category Contact is assigned? Using Outlook 1
T Outlook 2007 forms: Check boxes and free text boxes not retaining data Using Outlook 1
L check if send message appears in SendItems forder before moving Using Outlook 0
C Create a rule to only check new content in email - disregard original content Using Outlook 3
G Outlook rule check for messages not received Outlook VBA and Custom Forms 2
E Outlook could not create the work file. Check the temp environment variable Using Outlook 8
B Custom real time, time format check Outlook VBA and Custom Forms 1
B BCM shuts down everytime I try to import/export or check for error BCM (Business Contact Manager) 10
D Check whether mail item is proper for sending or not Outlook VBA and Custom Forms 5
P Check for the distribution list existence Outlook VBA and Custom Forms 1
H out to check whether outlook configured or not Outlook VBA and Custom Forms 1
M Check Profile info Outlook VBA and Custom Forms 1
L Check sent email and reply if have specific words Outlook VBA and Custom Forms 2
Z Check if email was sent Outlook VBA and Custom Forms 1
Z All Day Event Check Box Outlook VBA and Custom Forms 1
