Integrating Outlook and Projectwise
Alan McGowan
Outlook 2013 64 bit
Does anyone have any experience integrating Outlook with Projectwise? Specifically I'm looking for a way to save emails directly from Outlook in MSG format to a Projectwise folder
Unfortunately there aren't just folders. They sit on a specific server and normal access is through a specific projectwise application that requires users to login etc. It seems from what i've read online their is a API that should allow access via Outlook although couldn't find much documentation to get me started in the right direction. Thanks anyway
H Integrating Alexa & Outlook Pro 2021 Using Outlook 2
B Integrating BCM database with MSAccounting 2008 BCM (Business Contact Manager) 3
L new outlook contacts searching Using Outlook 2
W New Outlook PEOPLE blank Using Outlook 7
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 4
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
M Anyone integrated AI website builders with Outlook for automated client communications? Using Outlook 1
V Gmail in Outlook Using Outlook 2
T Where has the Copilot icon gone in my Outlook desktop client? Using Outlook 7
P New way by Microsoft to get people to use the new Outlook Using Outlook 4
T Constantly Have To Log In To Outlook On The Web Using Outlook.com accounts in Outlook 2
O Outlook 2024 not showing that messages are replied to or forwarded Using Outlook 3
C I don't understand Outlook or Microsoft, anymore Using Outlook 12
P My Feedback to Microsoft and their response; also New Outlook roadmap Using Outlook 0
L Android Outlook Doesn't Update PC Notification Changes Using Outlook 0
D.Moore Outlook desktop client suggested searches question Using Outlook 22
Y Outlook 2016 (64-bit) Copy Local Cal. Events to Another Cal. with Modified Reminder time Using Outlook 2
D Cannot logon to Outlook.com, or outlook on Mac, outlook not updating on ipad, iphone Using Outlook 1
J unable to get my new install of Outlook to display mailboxes in the single-line format. Using Outlook 1
D Legacy Microsoft Outlook for Mac Support will end in Oct 2025 Using Outlook 8
C Nasty Bug Lurking In Outlook For Years. The Trigger. Any Fix Or Workaround? Using Outlook 12
R Auto clicking Hyperlink in outlook Outlook VBA and Custom Forms 7
G Outlook translation feature is off Using Outlook 2
