Replace a string in body
Beeto
Outlook 365 32 bit
Hi all,
I have a problem with this code VBA. Works well when I send a message, replace the year. The problem is when I need to replay or forward a message, don´t replace and give me a Error 91. I would like this code for change the years old of company in my signature.
Thank for your help :).
***************Code**************************
Dim dataY As Date, year_X As Double
dataY = Date
year_X = Year(dataY) - 1973
Application.ActiveInspector.CurrentItem.HTMLBody = Replace(Application.ActiveInspector.CurrentItem.HTMLBody, "#year_old#", year_X)
Are you using the reading pane to reply? That doesn't use active inspector, it uses ActiveInlineResponse.
Actually, in looking closer, you're using item send - it doesn't use current item, just item - the message is the item in "item as object"
Try this instead -
dataY = Date
item.HTMLBody = Replace(item.HTMLBody, "#year_old#", year_X)
Beeto
Outlook 365 32 bit
Try this instead -
dataY = Date
Diane, you are the best :)! You were absolutely right about reading panel to answer or forward. I followed your suggestion and Works 100%. Thank you very much for share your know-how 🥂.
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 6
M Outlook 2013 Replace Subject with Conversation (a "hidden" value). Outlook VBA and Custom Forms 0
C How to replace or delete first instance of sentence in mail body? Outlook VBA and Custom Forms 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
Diane Poremsky How to perform a global search and replace Using Outlook 0
B Delete/replace old files and save new attachments Using Outlook 1
Diane Poremsky Replace Display Names with Email Addresses Using Outlook 0
mrje1 Is there a Find and Replace feature in Outlook 2016? Using Outlook 4
J Pull an email address from body and replace reply-to address Outlook VBA and Custom Forms 4
divan Outlook 2007 - Replace email body with custom text Using Outlook 9
E VBScript to replace module? Using Outlook 3
A How to replace column title in address book Using Outlook 1
V Replace only part of subject in OUTLOOK 2003 Outlook VBA and Custom Forms 1
A Replace olFolderContacts for Sharepoint lists in Outlook Outlook VBA and Custom Forms 5
P replace default outlook form with custom form Outlook VBA and Custom Forms 1
A How to replace getcontactsfolder (ol2007) in Outlook 2003 Outlook VBA and Custom Forms 2
skyfox VBA to search email subject field for a certain string Outlook VBA and Custom Forms 3
C Save Subject of Received Email as a String Outlook VBA and Custom Forms 1
P String manipulation in Outlook VBA Outlook VBA and Custom Forms 2
M Find a String in Email Attachment(s) Outlook VBA and Custom Forms 1
S [O2007] -> How to search for a string in the body and get the line number? Outlook VBA and Custom Forms 1
N Separate string in email body Outlook VBA and Custom Forms 3
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
J Outlook 2019 Regex email addresses from body Outlook VBA and Custom Forms 6
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
G Place jpg in body of email Outlook VBA and Custom Forms 1
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
