String manipulation in Outlook VBA
Is it possible to use string manipulation in Outlook VBA?
I need the first 14 digits of an email address for processing concerns.
Correct. VBA is pretty much the same between the office apps and in many cases, the same as VB. There are a few functions that Excel supports and Outlook doesn't, but left, right, trim, mid instr, instrrev are all supported in outlook.
Beeto Replace a string in body Outlook VBA and Custom Forms 2
skyfox VBA to search email subject field for a certain string Outlook VBA and Custom Forms 3
C Save Subject of Received Email as a String Outlook VBA and Custom Forms 1
M Find a String in Email Attachment(s) Outlook VBA and Custom Forms 1
S [O2007] -> How to search for a string in the body and get the line number? Outlook VBA and Custom Forms 1
N Separate string in email body Outlook VBA and Custom Forms 3
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
A How to Convert an Orphaned OST File Without Outlook or Exchange? Using Outlook 2
J Outlook Classic on desktop suddenly showing Contacts in 'new Outlook' format Using Outlook 4
S Rule on a shared mailbox only runs when my Outlook is open Using Outlook 4
B Sync Google Calendar with Outlook Using Outlook 5
