VBScript to replace module?
EdNerd
I am trying to implement my first Outlook "program". I've been doing this
with Word and Excel add-ins for years, but this is my first for OL.
First, I have to be able to work within the contraints of my company's
security policies. In the Trust Center, all options for Programmatic Access are
deselected and greyed out. Macro Security is likewise permanently set to
Wanrings for all macros. I have no trusted Publishers and am not allowed to add
any. I can manage add-ins, but I do not have (that I know of) any way to create
a DLL file as a COM add-in, nor can I install a program that would help me
create one.
From what I understand, that leaves me with using BAS module files. I'm okay
with that. I will have maybe 15-20 users to distribute these to, and I can't
count on any of them to understand anything about the VB Editor. Then again,
some of them might surprise me and have macros of their own - but I doubt
it.
I could issue instructions like:
-- Open Outlook and hit ALT+F11
-- Expand VbaProject.OTM, then expand Modules
-- Delete SaveMyEmailAttach
-- File >> Import File >> navigate to SaveMyEmailAttach and click Open
I'd prefer to get as much of that into a script as possible - if it is at all
in any way possible! Or find a much easier way altogether.
I'd love to hear anyone's thoughts.
Ed
If no one has macros, the easiest way is to drop it in the folder as an OTM. I'd ask if anyone is using macros and if not, use a logon script to drop it in the folder. I don't think the file is created until they open the VBE, so you could check for the presence of the OTM before copying it.
EdNerd
Hi, Diane. Thanks for chiming in. I don't grasp the concepts of what you said, though.
-- "Drop it": the BAS file?
-- "the folder": what folder?
-- "as an OTM": what's an OTM?
Sorry to be so dense. If you could help me learn this, I'd be most grateful.
Ed
EdNerd
Okay - never mind. A little bit of research and I found info about replacing the VbaProject.OTM file. That really looks like the best way to go for me, as long as no one else is using macros in Outlook.
Thanks for the boost!
Ed
D Security patch seems to kill vbscript on Enterprise Level Outlook VBA and Custom Forms 4
R VBScript Commands Outlook VBA and Custom Forms 2
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
R VBScript Sendmail not selecting correct 'from' address Outlook VBA and Custom Forms 3
B Recommended Outlook & VBScript Books? Outlook VBA and Custom Forms 3
K VBScript Outlook, add attachment Outlook VBA and Custom Forms 1
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
F VBScript to add pre defined text Using Outlook 5
D Custom form and VBScript Using Outlook 5
F VBScript copy contacts and remove duplicates Using Outlook 1
H Accessing a control on a frame in Outlook with VBScript Outlook VBA and Custom Forms 1
Y Creating a Task with VBScript Outlook VBA and Custom Forms 14
N VBScript does not run in Outlook 2003 Outlook VBA and Custom Forms 4
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 6
Beeto Replace a string in body Outlook VBA and Custom Forms 2
M Outlook 2013 Replace Subject with Conversation (a "hidden" value). Outlook VBA and Custom Forms 0
C How to replace or delete first instance of sentence in mail body? Outlook VBA and Custom Forms 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
Diane Poremsky How to perform a global search and replace Using Outlook 0
B Delete/replace old files and save new attachments Using Outlook 1
Diane Poremsky Replace Display Names with Email Addresses Using Outlook 0
mrje1 Is there a Find and Replace feature in Outlook 2016? Using Outlook 4
J Pull an email address from body and replace reply-to address Outlook VBA and Custom Forms 4
divan Outlook 2007 - Replace email body with custom text Using Outlook 9
A How to replace column title in address book Using Outlook 1
V Replace only part of subject in OUTLOOK 2003 Outlook VBA and Custom Forms 1
A Replace olFolderContacts for Sharepoint lists in Outlook Outlook VBA and Custom Forms 5
P replace default outlook form with custom form Outlook VBA and Custom Forms 1
A How to replace getcontactsfolder (ol2007) in Outlook 2003 Outlook VBA and Custom Forms 2
A Calling one module from another Outlook VBA and Custom Forms 2
230Grains iCloud COM Module Keeps de-selecting in Outlook 2013 Using Outlook 1
R Addins4Outlook TagIt! addin script or VBA module? Using Outlook 2
L Script to Macro in Module Using Outlook 36
S Exam 77-884: Managing Contact Module Options Using Outlook 4
