Outlook 365 VBA AUTO SEND WITH DELAY FOR EACH EMAIL
RealNPreston
Outlook 365 64 bit
I am trying to get a macro together that will set up an email from a list in excel and then set a delay on each email of between 5-13 minutes between sends. I have been trying to use the delay function and i have tried to use the loop function but it does not seem to work and I want to try and get the code to run.
I have gotten the delay to work one time to send one email, but then it will not loop to the next email. I have tried to find it online, but no luck so I figured I would look here. Any help would be great and I can provide the code if that helps.
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
N VBA, Rule that will Auto Reply based on time of day Outlook VBA and Custom Forms 1
D VBA script to auto download attachments and rename file according to subject line Outlook VBA and Custom Forms 23
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
