Why do I have to close and reopen Outlook for macros to work?
schwarznavy
When I login to my Windows 10 desktop, I open Outlook. I get no pop-ups. Macros don't work. I close Outlook. I open it again. I get no pop-ups. Macros work.
Any experience with this?
Enterprise Environment
Windows 10
Outlook 2016
What is your macro security level? If you have it set to the notification option, you should see the notification and need to allow macros. If you don't allow macros you will need to restart Outlook.
Hi Diane.
I login to Windows.
I open Outlook. No macro notification/prompt. Macros do not work.
I close Outlook.
I re-open Outlook. No macro notification/prompt. Macros DO work.
Are you saying that is expected behavior? Or are you saying I *should* be seeing a notification?
T Outlook 2021 hangs in close on taskbar occasionally Using Outlook 1
K Outlook font corrupted in some point sizes, resets on close/open Using Outlook 2
macdotcom Outlook 365 Outlook folder export to PST archival tool - close, but need a nudge Outlook VBA and Custom Forms 2
O Outlook 365 - Toolbar - Close all items - missing? Using Outlook 3
K Working with Explorer.Close event Outlook VBA and Custom Forms 3
Diane Poremsky How to Compact the Data File When you Close Outlook Using Outlook 0
Diane Poremsky Close a Meeting When the Room is Full Using Outlook 0
L Gmail POP, Android IMAP, Outlook 2013 setup close Using Outlook 5
D Close Oulook after sending emails via vba without outbox getting stuck. Outlook VBA and Custom Forms 1
F Automatically close email after selecting mark unread Using Outlook 1
S Pop up reminder while i close outlook Outlook VBA and Custom Forms 5
Y (Shared Folder) Using the preview pane to open and close a fax, without opening the email itself Using Outlook 1
C Open/Close Outlook - Via Excel VBA Using Outlook 2
J OL wont close after VB app runs Using Outlook 17
Q Looking for Outlook 2010 Close Event Id Exchange Server Administration 1
R Can't close Personal Folders after switching to Exchange 2010 Using Outlook 2
R Outlook and google calendar stuck if I close outlook Using Outlook 1
K The file c:\...\Outlook1.pst cannot be accessed because another workstation has modified it. Close a Using Outlook 2
R Outlook 2003 - Close parent form before opening child form Outlook VBA and Custom Forms 4
S Error 287 on Inspector.Close() Outlook VBA and Custom Forms 4
D Macro to Close Open Messages Outlook VBA and Custom Forms 3
E How to know if a Form.Close Event is the result of canceling Outlook VBA and Custom Forms 3
Q Why is BCM causing Outlook to close? BCM (Business Contact Manager) 2
V Move email using the Close event Outlook VBA and Custom Forms 11
R Close item Outlook VBA and Custom Forms 4
U Re: MailItem.Close() Outlook VBA and Custom Forms 1
H Outlook Does Not Really Close When I Close It BCM (Business Contact Manager) 1
S Outlook 2010 will not reopen upon closure Using Outlook 1
J Need replacement for iTunes to locally (USB) sync. iPhone 17 to Classic Outlook 2024 Using Outlook 2
Thomas Fast Best way to manage incoming customer emails automatically in Outlook? Using Outlook 1
I Outlook 2024 Windows 11 Gmail - sudden log in problems Using Outlook 9
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
W New Outlook PEOPLE blank Using Outlook 6
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 3
V Outlook created new profile? Using Outlook 1
