Outlook 2010 will not reopen upon closure
Hi all,
Brand new first ever post... so I apoligize if it has been posted many times before. I tried to search the FAQ and am not positve if there is another archive for common posts. I have several users running Windows 7 with Outlook 2010 on Exchange 2007 sitting on a 2008 SBS Server. Users are using a phone system that ties the outlook contacts to the phone contacts. If a users closes Outlook inadvertantly or by choice, it will not reopen again unless the user logs out and back onto their computer. Any thoughts? workarounds to keep from having to close all applications and logout and back in?
It sounds like the phone system is holding outlook open - next time it happens, ook in Task Manager on the Processes tab. You should see outlook.exe listed. Force it closed and it should reopen.
You might want to see if the solution here: Stop accidentally closing outlook will work for your users.
F Outlook 2010 and Hotmail Using Outlook 1
