Create Outlook Task from Template and append Body with Email Body
Post number 2 has been selected as the best answer.
STiGuy04
OS Version(s)
  1. Windows
Outlook 365 64 bit
Operating system::    Windows
Outlook version:     365
I have a macro to create a task from an email, but I want to use a template for the base task information including body text. I'm pretty sure when I try to pull in the body of the email it's overwriting my template. How do I preserve that and append my template with the email body? Basically task body first then email body goes below it in the task.
If I remove this line my template pulls in just fine, but of course I'm missing the email body: objtask.Body = objMail.RTFBody
Script below:
Sub NewTask()
Dim objtask As Outlook.TaskItem
Set objtask = Application.CreateItemFromTemplate("C:\Program Files (x86)\Microsoft Office\Templates\Template.oft")
For Each objMail In Application.ActiveExplorer.Selection
objtask.Subject = objMail.Subject
objtask.StartDate = objMail.ReceivedTime
objtask.Categories = "Category Name"
objtask.Save
objtask.Display
Set objtask = Nothing
Set objMail = Nothing
you need to use
objtask.Body = objtask.body & objMail.RTFBody
might need a vbcrlf or two in between
objtask.body & vbcrlf & objMail.RTFBody
you need to use
I will give this a shot and report back. Thank you!
you need to use
ok so that gets me closer, however, the objMail.RTFBody section of the stuff being brought in turned into asian fonts it looks like. The upper body of the task has my template and then below is asian fonts assuming it is some sort of corrupted or mistranslated text from the body from the email.
figured it out. It was the RTFBody that was screwing it up. I just changed it to objMail.Body and it pulled through just fine. I don't know VBA well so just trying different things till it works.
J Create new outlook task into task subfolder using vba Using Outlook 6
Diane Poremsky Create a custom field for Outlook messages Using Outlook 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages Using Outlook 0
Diane Poremsky Manually create a POP3 account in Outlook 2007 Using Outlook 0
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
Diane Poremsky Use VBA to create an Outlook Search Folder for Sender Using Outlook 0
Diane Poremsky Create an Outlook appointment from an email message Using Outlook 4
Diane Poremsky Outlook Crashes When You Reply or Create a New Message Using Outlook 0
I Create custom Outlook 2013 Rule in Office 365 Outlook VBA and Custom Forms 5
C Edit/Create Pen Not Working Outlook 2013 Using Outlook 1
Rupert Dragwater Outlook could not create the work file Using Outlook 5
J Outlook Rule - Create Link in Forwarding Message Outlook VBA and Custom Forms 2
E Create a URL hyperlink in an Outlook custom form? Outlook VBA and Custom Forms 2
Rupert Dragwater How to delete old rules and create new in Outlook 2013 Using Outlook 12
P Cannot open Options Menu Outlook 2007 and Cannot create a new profile Using Outlook 0
C Outlook 2007 cant create new account Using Outlook 7
G Outlook could not create the work file Using Outlook 0
K Outlook Cached Mode - can't create rules to move email to another mailbox Using Outlook 2
O Can't create new email or access email acounts Outlook 2003 Using Outlook 1
S [outlook-users] Create contact group from other user's contacts Using Outlook 1
L Create hyperlinks to bookmarks in Outlook 2003 otf file Using Outlook 1
B How do I create and send mail in Outlook 2003 from code? Using Outlook 5
O Outlook 2010 - How to create custom Group By Arrangements for email Using Outlook 3
J Create or Import a Outlook Rule through C# code. Outlook VBA and Custom Forms 2
F can I use Outlook 2007 to create peer review/approve/reject forms Outlook VBA and Custom Forms 1
E Outlook could not create the work file. Check the temp environment variable Using Outlook 8
S Create a new Outlook MailItem in an Outlook folder(not a draft) Outlook VBA and Custom Forms 2
D Create a macro in Outlook to run a rule Outlook VBA and Custom Forms 32
B How to create the customized Outlook SQL DASL for selected days? Outlook VBA and Custom Forms 2
N How Can I create an Outlook Macro to import calendar? Outlook VBA and Custom Forms 1
P Create appointment to custom (shared) outlook calendar Outlook VBA and Custom Forms 3
S HELP: Create Buttons in Outlook Email body or Tool bar Outlook VBA and Custom Forms 1
N How to create hidden rule in outlook 2007 Outlook VBA and Custom Forms 3
N create stationary in outlook Outlook VBA and Custom Forms 1
