Default Selection For Multi-Select List Box
srmsrm
Outlook 365 64 bit
Operating system::    W10 Desktop
Outlook version:     Outlook 365 Classic
Email type or host:    IMAP
I have Outlook 365, Desktop Version, W10
On my custom form I created a custom field (Keywords / Text).
I created a List Box and used the custom field.
I have the multiple selection working (using fields in the "Possible values:" field) ; however, I cannot figure out if there is a way to have a default selection in the multiple selection field when creating a new contact. Entering a initial value does not work for me.
In searching, there are conflicting answers, different sample code to use, but nothing works.
My first question - is a default selection possible for a multi select field, and secondly, if yes how can it be completed.
Any guidance would be greatly appreciated.
Shawn
Here is some sample code I was able to locate
Function Item_Open()
Dim olPage As Page
Dim ctl As Control
Set olPage = Item.GetInspector.ModifiedFormPages("General")
Set ctl = olPage.Controls("Follow Up Type")
If ctl.ListCount = 0 Then
ctl.AddItem "First Choice In The List"
ctl.AddItem "Second Choice In The List"
ctl.AddItem "Third Choice In The List"
' Add more items as needed
ctl.Selected(0) = True ' Select "First Choice In The List"
ctl.Selected(2) = True ' Select "Third Choice In The List"
End Function
K Default Account and Signature Selection Using Outlook 5
T Default fields Using Outlook 3
V select default calendar Outlook VBA and Custom Forms 3
G Outlook 2021 (New) doesn't respect default browser Using Outlook 9
R Outlook ribbon menu default? Using Outlook 7
T How to set Default FONT for Email composing ? Using Outlook 0
J Calendar events created on iPhone automatically changing default alert from 'None' to 'Time of Event' Using Outlook.com accounts in Outlook 0
A Outlook 365 New Appointments All saved to a 365 default calendar on Mac Using Outlook 0
P Outlook 2016 Change Paste Special Default Format Using Outlook 8
P default font when sending email from browser Using Outlook 1
A force outlook to default to MY calendar Using Outlook 3
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
V Accepted meetings do not get the default reminder Using Outlook 0
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
O How come default profile changed? Using Outlook 2
T Outlook changes default account Using Outlook 1
V VBA when replying + Default Account Using Outlook 2
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
P Outlook 2016 Not Default Client Using Outlook 5
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
N How to delete default folder "Contacts" (olFolderContacts) in a .pst file Using Outlook 8
