Phantom VBA Running
  • Thread starter Thread starter Brian D
Brian D
I created a VBA to move items from one folder to another after the
message was a certain age. When I open Microsoft Visual Basic Editor
(ALT-F11) the scripis not lsited. How do I find it. I want to disable
it.
If the macro runs, it must be available in any module. Press ctrl+r to see
the object explorer, open any modules (there must be at least
'ThisOutlookSession').
If you mean the dialog that opens with alt+f8, that one only lists macros
declared as Public and don't take arguments.
Best regards
Michael Bauer
Am Fri, 25 Sep 2009 11:30:34 -0700 (PDT) schrieb Brian D:
> it.
> Thanks!
J Outlook 2013 - changed an account from POP3 to IMAP, POP3 'Phantom' appears Using Outlook 15
P Phantom Outlook 2010 account Using Outlook 0
