Outlook Script ( using calendar function in a form)
  • Thread starter Thread starter bbnimda
bbnimda
Hi all,
I use a custom Form, and I added a function that create an entry in my
calendar, this small function contain 4 item
A field for the date
a field for the time (a combo from 00:00 to 23:30) read only
and two button (ok / Cancel)
I have Pb whith the date field because I must fill it and I must use the
right syntax
is there any way to use in this field a calendar and to select the date by
a simple clic
Tks
NB: I'm using outlook 2003 / exchange 2003
It's possible, but far from simple. Outlook has no date picker control
available to custom form programmers (which, by the way, is one reason why
the first page of the appointment, journal, and task forms is not editable).
See http://www.outlookcode.com/article.aspx?id=26 for controls you can add.
Sue Mosher
"bbnimda" wrote:
> Hi all,
> right syntax
> a simple clic
> Tks
Hi Sue,
I added date picker to my tool box, localy it work's fine but when I probe
my form on an other PC, my form don't work properly and I have an error
message to inform me that the object isn't found => i think that is the
date picker , so how can I solve the PB, whithout copying the ocx on ALL
COMPUTER of the network
tks
"Sue Mosher [MVP]" <suemvp@gmail.com> a écrit dans le message de news:
4A3F8EFE-1F5F-49A3-835C-32F717B0F70D@microsoft.com...
> editable).
> add.
> > Sue Mosher
> "bbnimda" wrote:
> > Hi all,
> > right syntax
> > by
> > a simple clic
>> Tks
There is no other solution. If you want the form to work properly for each
user, each machine needs to have all the components that the form uses,
including any controls that are not included with Outlook. Therefore, each
machine needs the date picker, or you need to remove that control and just
use a text box bound to your date field.
Sue Mosher
"bbnimda" <wahhhran-vba@yahoo.fr> wrote in message
news:uDhNJquUKHA.5004@TK2MSFTNGP06.phx.gbl...
> Hi Sue,
> tks
> > why
> > editable).
> > add.
>> "bbnimda" wrote:
> >> Hi all,
> >> right syntax
> >> by
> >> a simple clic
>>> Tks
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
J Email Parsing VBA Script for Outlook - NEEDED Outlook VBA and Custom Forms 7
J VBS Script: How to execute in Outlook Outlook VBA and Custom Forms 8
Hudas Outlook VBA script reverting back to previous changes Outlook VBA and Custom Forms 2
M Outlook Rule To Redirect Mail - Script to overcome lack of cc's & others Using Outlook 0
C Outlook Script Error Using Outlook 0
L Outlook 2007 Macro to Run a Script From a Contact Form Using Outlook 41
L Limit VBA Script to one Outlook account Using Outlook 1
S Outlook 2010, need script for rules & Warnings Using Outlook 3
C Outlook 200? - Script Export Rules Using Outlook 1
R Change Outlook 2010 Exchange server address via registry or script Using Outlook 5
P Preventing permanent deletions in Outlook on the Web Using Outlook 0
L any trick to embedding images in new outlook and outlook on the web contacts? Using Outlook 4
L new outlook contacts searching Using Outlook 5
W New Outlook PEOPLE blank Using Outlook 6
C New Outlook issues with Gmail, particularly labels/folders Using Outlook 3
V Outlook created new profile? Using Outlook 1
J Outlook inbox question Using Outlook 4
