Drag and drop
  • Thread starter Thread starter Mike
Mike
I have an application that requires that file names be less that 90
characters long. I can't seem to make my users do this when they save .msg
files themselves. So we have one macro in Outlook that will format the file
name corretly for them. A couple of users get around this by dragging and
dropping their messages to the file system. I would like a macro that gets
fired when a drag and drop is done and tests the file name for formatting.
How do I get a macro to run when they initiate a drag and drop and how do I
access the filename of the messages they dragged?
Mike
There are no events that fire when a message is dragged from Outlook to the
file system
Dmitry Streblechenko (MVP)
"Mike" <Mike> wrote in message
news:69FFF114-F876-4FBE-8210-9CC61A3590F8@microsoft.com...
> .msg
> file
> gets
> I
> Mike
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
K Cannot consistently drag and drop .msg files into Outlook 2010 Using Outlook 0
F Tumblr - Drag & Drop files (pictures) into Outlook? Using Outlook 12
C Cannot drag and drop or create folder in PST file folders Using Outlook 1
L Copying Emails using drag and drop Using Outlook 2
V Drag and drop into Outlook folders Using Outlook 2
T drag drop/opening drop down/single click acts like double/highlighting Using Outlook 7
J Problem using drag and drop to attach an html email in Outlook 2010 Using Outlook 18
H Drag and Drop Outlook mails into a Windows Form Control with eml extension Outlook VBA and Custom Forms 1
N Drag and drop attachment in outlook addin Outlook VBA and Custom Forms 4
S Drag-and-drop to Custom Task Pane Outlook VBA and Custom Forms 2
A Implementing Drag and drop events in outlook Outlook VBA and Custom Forms 7
P Drag and Drop mails from Outlook to Clarion6 Application Outlook VBA and Custom Forms 5
S Renaming while drag and dropping to file Using Outlook 1
B Right click-drag no longer creates hyperlinks Using Outlook 2
S cannot drag emails to personal folders BCM (Business Contact Manager) 1
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
A Automatically send email based on drop-down field? Outlook VBA and Custom Forms 2
Diane Poremsky No drop down calendars in Outlook 2010 Print Options Using Outlook 0
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
P Field in Forms displayed depending on the Item chosen from drop-down-list BCM (Business Contact Manager) 1
M Add custom locations to Outlook Forms "Look In:" drop-down list Using Outlook 5
M How do I link a drop down box to a percent complete box Using Outlook 4
R Display multiple accounts as drop down in the from field in New Mail Using Outlook 1
S Outlook addin formregion as a drop down Outlook VBA and Custom Forms 6
S RE: Template with drop down Outlook VBA and Custom Forms 3
C Drop Down Box in Email Template Outlook VBA and Custom Forms 2
