Drag-and-drop to Custom Task Pane
  • Thread starter Thread starter stevusuk
stevusuk
I'm trying to implement a Custom Task Pane that will allow me to drag-and-
drop an email item in it. At the moment, I'm getting no-where - every time I
drag over the email item I get the black circle with a line through it cursor
and the drag-drop event doesn't fire. I've set the allow drag-drop
properties on the user control and components to true to allow dra-and-drop
but it's not working.
What else is required to get this working? Any help would be gratefully
received.
Oh I forgot to mention - this is Outlook 2007, using VSTO 3.0 in Visual
Studio 2008.
> received.
Hi , I am facing same issue. were you able to resolve this issue?
07-Oct-09
I am trying to implement a Custom Task Pane that will allow me to drag-and-
drop an email item in it. At the moment, I am getting no-where - every time I
and the drag-drop event does not fire. I have set the allow drag-drop
but it is not working.
received.
Previous Posts In This Thread:
On Wednesday, October 07, 2009 3:16 AM
received.
On Wednesday, October 07, 2009 3:17 AM
Studio 2008.
stevusuk wrote:
Get Silverlight 4 Installed: Tips and Tricks
http://www.eggheadcafe.com/tutorial...b-f54c56a64ed9/get-silverlight-4-install.aspx
R PST->Outlook.com (Import vs Drag-n-Drop methods Using Outlook.com accounts in Outlook 2
K Cannot consistently drag and drop .msg files into Outlook 2010 Using Outlook 0
F Tumblr - Drag & Drop files (pictures) into Outlook? Using Outlook 12
C Cannot drag and drop or create folder in PST file folders Using Outlook 1
L Copying Emails using drag and drop Using Outlook 2
V Drag and drop into Outlook folders Using Outlook 2
J Problem using drag and drop to attach an html email in Outlook 2010 Using Outlook 18
H Drag and Drop Outlook mails into a Windows Form Control with eml extension Outlook VBA and Custom Forms 1
M Drag and drop Outlook VBA and Custom Forms 1
N Drag and drop attachment in outlook addin Outlook VBA and Custom Forms 4
A Implementing Drag and drop events in outlook Outlook VBA and Custom Forms 7
P Drag and Drop mails from Outlook to Clarion6 Application Outlook VBA and Custom Forms 5
S Renaming while drag and dropping to file Using Outlook 1
B Right click-drag no longer creates hyperlinks Using Outlook 2
S cannot drag emails to personal folders BCM (Business Contact Manager) 1
M Same file "stuck" on top of file list in "Attach File" drop down Using Outlook 4
A Automatically send email based on drop-down field? Outlook VBA and Custom Forms 2
Diane Poremsky No drop down calendars in Outlook 2010 Print Options Using Outlook 0
P BCM 2013 Contacts Form Drop Down Box Bug BCM (Business Contact Manager) 1
P Field in Forms displayed depending on the Item chosen from drop-down-list BCM (Business Contact Manager) 1
M Add custom locations to Outlook Forms "Look In:" drop-down list Using Outlook 5
M How do I link a drop down box to a percent complete box Using Outlook 4
R Display multiple accounts as drop down in the from field in New Mail Using Outlook 1
S Outlook addin formregion as a drop down Outlook VBA and Custom Forms 6
S RE: Template with drop down Outlook VBA and Custom Forms 3
C Drop Down Box in Email Template Outlook VBA and Custom Forms 2
D Custom Form Overwritten? Outlook VBA and Custom Forms 20
D Custom form now unusable Outlook VBA and Custom Forms 1
H Outlook 2016 Custom made "Message" column Outlook VBA and Custom Forms 7
sjbtax Update Task Custom Field based upon Task Overdue Status Outlook VBA and Custom Forms 8
A How to reduce size of custom contact form? Outlook VBA and Custom Forms 3
