VBA to assign category on calendar item does not work ?? why ??
  • Thread starter Thread starter PGT
P
PGT
Below i wrote code to assign a categorie to a calendar item based on the word "vrij" in the subject.
I got to automate a lot of words for a lot of people so this just the first keyword.
I think this code should work.. but somehow it doesnt
I use Outlook 2003 with macro security set to lowest level. The code is placed in "this outlook session"
Any ideas why it doesnt work ??
Dim WithEvents colRDVItems As Items
Dim NS As Outlook.NameSpace
Set NS = Application.GetNamespace("MAPI")
Set colRDVItems = NS.GetDefaultFolder(olFolderCalendar).Items
Set NS = Nothing
Private Sub colRDVItems_ItemAdd(ByVal Item As Object)
If Item.Class = olAppointment Then
If InStr(LCase(Item.Subject), "vrij") > 1 Then
AddCat Item, "Holiday"
Item.Save
Sub AddCat(itm, catName)
arr = Split(itm.Categories, ",")
If UBound(arr) >= 0 Then
' item has categories
For I = 0 To UBound(arr)
If Trim(arr(I)) = catName Then
' category already exists on item
' no need to add it
itm.Categories = itm.Categories & "," & catName
' item has no categories
itm.Categories = catName
Try the InStr() function with the correct arguments and see if the code
works. You need to either put a comma at the beginning of the function
arguments or put an explicit starting point:
If InStr(1, LCase(Item.Subject), "vrij") > 0 Then
If that doesn't help you need to step the code when the event handler fires
and see what's going on. That's if the code is running at all, that's not
clear from your post.
"PGT" <user@msgroups.net/> wrote in message
news:OdxMItwgKHA.6096@TK2MSFTNGP02.phx.gbl...
> first keyword.
> Private Sub Application_Startup()
> Set NS = Nothing
> End Sub
> Item.Save
> End If
> End If
> End Sub
> ' no need to add it
> Exit Sub
> End If
> Next
> Else
> End If
> End Sub
instr can be used this way giving it a startposition is not required. It seams to me this code is not running at all.
if for example i put a msgbox allert inside colRDVItems_ItemAdd it doesnt popup, when i add a new item to my calendar. I strongly think this code is OK, but maybe the default VBA isnt running or ..??? can you try this code?? (note ol2003 requires low macro security for this to work).
The code may not be running, or if the subject starts with your test string
it will never go past the If tests. I prefer to use a starting index, but
with or without that if the index of where that string starts is 1 the If
test will fail unless you test for > 0.
Does any other VBA code run for you?
news:O3urTWxgKHA.1824@TK2MSFTNGP04.phx.gbl...
If you want the function to ignore lower/upper cases, use the start
parameter and vbTextCompare:
pos=Instr(1, Item.Subject, "vrij", vbTextCompare)
Are you sure, "vrij" doesn't start at the beginning of the Subject? If it
does, the function would return 1, and that is not > 1.
Best regards
Michael Bauer
Am Tue, 22 Dec 2009 06:46:41 -0800 schrieb PGT:
yeah i got that >1 replaced by >0
i found it myself after the post.
Now i notice sometimes this code works other times it seams this macro is not running, strange as it should run always.
i restart outlook and then sometimes it works other times not, i'm not sure what is going on, its not the outlookspy
soadfan assign category (VBA) Using Outlook 7
