Range for Body of E-Mail
  • Thread starter Thread starter BillCPA
BillCPA
I am trying to use a range of cells in Excel as the body for an e-mail in
Outlook. The name for the range is 'DuesReceipt'. It doesn't seem to like
setting olBody to the range. Can someone help?
Public olToName As String
Public olccName As String
Public olbccName As String
Public olSubject As String
Public olBody As String
Public olRange As Object
Public olAttach1 As String
Sub SendReceipt()
Dim olMail As MailItem
Dim SigString As String
Dim Signature As String
Dim xx As Integer
Dim yy As Integer
Dim zz As Integer
Set olApp = New Outlook.Application
SigString = "C:\Documents and Settings\...\Signatures\BillLong.txt"
If Dir(SigString) = "" Then
Signature = GetBoiler(SigString)
Signature = ""
olToName = Range("K5").Value
olSubject = "Dues Receipt"
Set olRange = Range("DuesReceipt")
Set olMail = olApp.CreateItem(olMailItem)
With olMail
> To = olToName
> Subject = olSubject
> Body = olRange
> Send
Set olMail = Nothing
Set olApp = Nothing
Bill @ UAMS
Have you tried using the Text property of the range?
Sue Mosher
"BillCPA" <Bill @ UAMS> wrote in message
news:21B7CA5A-5C70-488F-ACEB-2F3CB305F131@microsoft.com...
> like
> Sub SendReceipt()
> Dim olApp As Outlook.Application
> Dim xx As Integer
> Dim yy As Integer
> Dim zz As Integer
> Else
> Signature = ""
> End If
> With olMail
> .To = olToName
> .Subject = olSubject
> .Body = olRange
> .Send
> End With
> Set olApp = Nothing
> End Sub
> > Bill @ UAMS
D DB/Object/Record vs File/List/Range Terminology Outlook VBA and Custom Forms 0
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
T Search for incoming e-mails for a specified time range Using Outlook 1
F Finding Meetings/Tasks in a date range Using Outlook 1
R Calendar Appointment Hour Range Using Outlook 1
J Dynamic date range for Outlook Search folders Using Outlook 2
M Outlook Appointment Item exceeds beyond the date range Using Outlook 2
M Outlook Appointment item does not show the item outside the date range Using Outlook 2
S Printing Selected Date Range in Monthly Style Using Outlook 1
C Duplicate emails from pop but only for certain date range? Using Outlook 4
D Print Macro with Page Range? Using Outlook 9
P View emails sent by time range excl weekends Outlook VBA and Custom Forms 1
B Copy Range of Cells from Excel Outlook VBA and Custom Forms 1
T exception when I call ActiveDocument.Range(0,0).Editors.Add(-1) Outlook VBA and Custom Forms 2
V Get selected option in recurrence range group Outlook VBA and Custom Forms 4
U Save messages and attachments for a date range Outlook VBA and Custom Forms 2
M Outlook 365 adding standard message in body of template email Outlook VBA and Custom Forms 3
B 10 Practical Tips for Healthy and Sustainable Weight Loss10 Steps to Achieving Your Dream Body Outlook VBA and Custom Forms 0
G Retaining Tabs in outlook body Using Outlook 2
H Copying email address(es) in body of email and pasting in To field Outlook VBA and Custom Forms 1
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
K Incorporate selection from combobox into body of email Outlook VBA and Custom Forms 0
J Outlook 2019 Regex email addresses from body Outlook VBA and Custom Forms 6
Beeto Replace a string in body Outlook VBA and Custom Forms 2
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
G Place jpg in body of email Outlook VBA and Custom Forms 1
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
