Calendar Appointment Hour Range
Reinhard
I confirgured iCloud with my Outlook and I have a problema with the hour range in Calendar. When making an appointment in the afternoon, it is impossible to set it for more than 30 minutes. When clicking on the hour box of the "end Time" it opens immedaitly with the option "12,5 hours" and it does not allow to scroll back and leave it at 1 hour, for example. Whatever end time you enter, it leaves it at 30 minutes. This problem does not appear when the start time is in the morning. And also does not appear in the Outlook Calendar, only in the Outlook-iCloud version.
O Calendar - appointment templates and categories Using Outlook 1
R Recover Deleted Appointment in Calendar Using Outlook 0
A Get shared calendar name or id in custom appointment form Using Outlook 0
Diane Poremsky Send an Email When You Add an Appointment to Your Calendar Using Outlook 0
J Outlook calendar...How to add an event or appointment without a border around it? Using Outlook 9
D Calendar appointment, type 2 Using Outlook 2
M Create an Appointment from XL Spreadsheet in a Shared Calendar. Outlook VBA and Custom Forms 1
L Showing @live account in outlook 2013 calendar as private appointment Using Outlook 1
M Email notification on creation of an appointment shared calendar? Outlook VBA and Custom Forms 3
anoble1 How to create an email with a link to add a calendar appointment Using Outlook 1
I how to create appointment using saved template onto public folder shared calendar Using Outlook 3
R How to copy outlook 2010 shared calendar appointment or meeting to personal calendar by vba? Outlook VBA and Custom Forms 1
D Reoccuring appointment issues when exporting Calendar to Excel Using Outlook 3
S Calendar deletes appointment after entry from both Outlook and Icloud calander Using Outlook 1
R OL2010 Calendar Appointment Highlighting Text issue Using Outlook 3
W ghost appointment in calendar.ics Using Outlook 2
D Selecting shared calendar for appointment/meeting templates Using Outlook 2
P Appearance (Width) of Calendar Appointment "Show as (Free/Busy/etc)" Indicator Using Outlook 1
B Outlook Calendar Appointment Problem Using Outlook 1
P Create appointment to custom (shared) outlook calendar Outlook VBA and Custom Forms 3
J Get Dates of Recurring Events in Shared Appointment Calendar Outlook VBA and Custom Forms 4
B Appointment Items in Public Folder calendar Outlook VBA and Custom Forms 2
T How to copy an appointment from a public calendar to personal cale Outlook VBA and Custom Forms 3
H add an appointment for a custom calendar, vba excel Outlook VBA and Custom Forms 2
G Forms error on iCloud calendar Using Outlook 18
V select default calendar Outlook VBA and Custom Forms 3
M Calendar items have a pale pink blushing Using Outlook 3
T Cannot delete a calendar Using Outlook 0
F Show events in Monthly Calendar Using Outlook 3
