Outlook Calendar Appointment Problem
broosth
One of my clients works in an Exchange environment. When she forwards a Calendar entry to another employee, the employee receives a vcalendar attachment that opens as a Calendar entry on their copy of Outlook.
When she sends the same email to me via POP3 email, the attachment is simply a forwarded email message, with the vcalendar text as the email body.
When I forward her a calendar entry, she receives it properly.
Is this an Outlook configuration issue, or an issue of Exchange vs POP3 message processing?
I guess it's more like a little of both. Outlook's default is to convert RTF to HTML when sending to an internet address plus the Exchange server can be configured to never send RTF to the internet. Either of those settings can make meetings and forwarded appointments not work.
Is she inviting your or forwarding the appointment to you?
If forwarding, she should choose the option to forward as an ical.
If iniviting, have her check the setting in Tools, Options, Calendar - 'when sending over the internet, use ical format' should be checked.
J Outlook calendar...How to add an event or appointment without a border around it? Using Outlook 9
L Showing @live account in outlook 2013 calendar as private appointment Using Outlook 1
R How to copy outlook 2010 shared calendar appointment or meeting to personal calendar by vba? Outlook VBA and Custom Forms 1
S Calendar deletes appointment after entry from both Outlook and Icloud calander Using Outlook 1
P Create appointment to custom (shared) outlook calendar Outlook VBA and Custom Forms 3
B Sync Google Calendar with Outlook Using Outlook 5
icacream Outlook 2021 - Google calendar in the peek Using Outlook 0
L Synch Outlook 365 calendar with iPhone Using Outlook 0
L Duplicate calendar entries in Outlook 365 Using Outlook 3
G Stop Outlook 365 adding meetings to calendar Using Outlook 1
J Event/Meeting in Outlook Does Not Align with SharePoint Calendar Using Outlook 5
A force outlook to default to MY calendar Using Outlook 3
HarvMan Toggle between calendar and email in Outlook 365 Using Outlook 12
M Outlook calendar is missing Using Outlook 2
A Any way to make Outlook Calendar invitations look right to Gmail/Google Calendar users? Using Outlook 3
I Outlook is stuck at "Updating Calendar" Using Outlook 1
AmonRa Outlook 365 calendar - too much white space Using Outlook 0
B Outlook Calendar not coming down from cloud Using Outlook 2
HarvMan Outlook 365 Calendar Using Outlook 13
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Using Outlook 2
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
C Put Day of Year into Outlook Calendar Outlook VBA and Custom Forms 2
